| Ford Tractors Discussion Forum |
Topic: 3 point lift HICCUPING
[Return to Forum]
| Author |
[Modern View]
| Rickhoot
10-08-2012 16:57:26
70.251.81.189
My 2910 Ford lift is Hiccuping. I read through the post and found some of the same issues. I didn"t find out the solution. I have my lift cover off and all the valve plugs out as well as the piston. The valve bodies look good! The cyclinder has some scuffing as well as the piston. The O-ring and nylon ring look good! I will replace all o-rings and check all the adjustment in the set up (manuel). Maybe someone could guide me in the right direction here. The other guy put his all back together and it still had the Hiccup problem. Please help! Thanks |
| Rickhoot
10-26-2012 11:49:35
205.175.225.22
Re: 3 point lift HICCUPING in reply to Rickhoot, 10-08-2012 16:57:26
| I found the O ring to be wore flat on the cyclinder piston. I also found the 2910 tractor I have has a cyclinder from a 4110 which has a 3.5" bore. Really confuseded the NH Dealership parts boys. I just bought for the 4110 like I knew what I was doing. Honed and resealed the lift cyclinder and relpaced all the valves o rings and works great so far. Thanks for all the help. Rickhoot |
| soundguy
10-09-2012 04:51:09
184.245.112.212
| | i agree. yuo are seeing leakdown and regen. i'd hone the cyl to smooth it.. then re-oring/washer the piston and see what you get. |
| Brian Allen
10-08-2012 17:57:32
142.169.215.28
| Rickhoot
How much wear is in the cylinder bore?
My rule of thumb with any hydraulic system is: if you can feel the scratch when you run your finger nail over it, it needs to be repaired or replaced.
What is happening when the 3PH hiccups is: The pressure drops off in the system, and the lift lowers a bit, until the control energizes and provides more oil pressure to send it back up again.
So, all you need to do is find where it is leaking. It may be the cylinder, any of the connection points, or the relief valve may be faulty.
Keep looking and you will find it!
You can make an adapter and run the top cover (off the tractor with air pressure) this is a lot easier to find leaks.
Post back with what you find!
Brian |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
