TractorLinks.com
Order Ford 4000 Parts Online
Re: Ford 4000 4 cyl gas Solenoid?
soundguy
10-08-2012 11:14:24
could it be?
it might.
might also be a bad trans top switch ( check by placing tractor in neutral, blocking clutch down, then using a jumper wire to jump terminal on solenoid hooked to trans switch to ground. )
could also be wire connections.
could be a bad power wire to switched hot connection on solenoid.
could be solenoid itself
or could be the starter.
jump out power and test ground to solenoid.. the easiest to do.. etc..
ScubaInstr
10-08-2012 11:32:34
 Re: Ford 4000 4 cyl gas Solenoid? in reply to soundguy, 10-08-2012 11:14:24
Ok - Will do the ground test when I get home today.
Question -> Why do I block the clutch down if it's in neutral?
Thanks!
Tommy D.
soundguy
10-09-2012 04:37:42
 Re: Ford 4000 4 cyl gas Solenoid? in reply to ScubaInstr, 10-08-2012 11:32:34
yup.. as another said.. blocking the clutch is just one more level of prudence in trying NOT to get run'd over.. :)
Steve Brussell
10-08-2012 11:58:26
Block the clutch for extra pre-caution. Getting run over by your tractor will really ruin your day.
