| Ford Tractors Discussion Forum |
Topic: loose spring in carberator bowl
[Return to Forum]
| Author |
[Modern View]
| RJSw/NAA
10-08-2012 11:07:10
174.60.70.56
I was cleaning out my backup carb because the one I am currently using leaks gas. Before I swap them out, I wanted to make sure this one was clean and ready to go. While carrying it over to the compressor hose the little spring fell out. Just so happens my IT shop service manual is missing those pages due to a bad collation job. Before I drive to TSC to get the manual replaced with a complete copy, thought I would post here. Anyone recognize that little one inch spring? |
| RJSw/NAA
10-10-2012 08:32:09
174.60.70.56
Re: loose spring in carberator bowl in reply to RJSw/NAA, 10-08-2012 11:07:10
| Choke flapper valve spring it is. And I also know why it fell out. one of the hooks on the end broke off. Curses. |
| Sean in PA
10-09-2012 04:49:52
71.224.102.32
Re: loose spring in carberator bowl in reply to white halftrack, 10-08-2012 11:07:10
| Quoting Removed, click Modern View to see
According to the parts diagrams, the float support spring was only used in the carbs for the 172 ci engine from 1/1/1955-12/31/1957. Seeing as how the NAA had a 134 ci engine and was only made in 1953 & 1954, I figured that spring didn't apply. |
| 36 coupe
10-08-2012 17:27:21
66.186.169.176
| some carberators have a float support spring and bracket in the bowl.The choke plate spring has a hook on both ends. |
| Sean in PA
10-08-2012 12:44:20
71.224.102.32
| A picture of the spring might help
The parts diagram for the NAA carb shows 5 different springs:
Carburetor Main Adjust Needle Spring
Carburetor Idle Adjust Needle Spring
Carburetor Throttle Lever Adjusting Screw Spring
Carburetor Choke Shaft Spring
Choke Flapper Valve Spring
The first 2 are installed ahead of each of the needle valves, so if the needle valves are in place, it's unlikely to be either of these. The next one is on the exterior of the carb on the throttle linkage, so if it "fell out" I would guess it wasn't that one. The next one is also on the exterior of the carb, on the choke shaft, so the same probably applies about it not having "fell out". The choke flapper spring, which old already mentioned, is in the throat of the carb, so it seems to be the likely suspect. |
| old
10-08-2012 11:56:50
209.86.226.40
| Do not know that it would be an inch long but the only spring I can think of that would just fall out of a carb if you did not have it in pieces would be the choke butterfly flapper spring |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
