| Ford Tractors Discussion Forum |
Topic: Ford 4000 4 cyl gas Solenoid?
[Return to Forum]
| Author |
[Modern View]
| ScubaInstr
10-08-2012 10:01:47
72.37.249.140
Here is my problem..... Ford 4000 (4 cyl gas) *most* of the time starts fine. It has gotten now where a lot of times I push the button, and "click" and nothing else. I can subsequently push sometimes several, sometimes one or two more times, and it will finally engage the starter and crank. Battery is good, and alternator is charging. Verified with a volt meter.Could the solenoid be my problem? All guidance is appreciated. Thanks! Tommy D... |
| crazylocha
10-09-2012 08:04:51
142.197.202.50
Re: Ford 4000 4 cyl gas Solenoid? in reply to ScubaInstr, 10-08-2012 10:01:47
| And when checking battery cables etc., we mean CLEAN cables AND spots where they connect. A little wire brushing goes a long way.
About blocking the clutch...
My neighbor Fred. Very good man. Has a hay farm in Vermont with 3 4000's, a 5000, and the wife's 3000. Was out this spring/early summer bailing. Decided he needed to hop off tractor and took out of gear and left running. Doing whatever it was he felt like he needed to do, one slip at wrong time and tractor rolled over his chest, baler over his head. He died once in ambulance on way to local hospital, second time in the chopper ride to bigger hospital in region. That was May I think. He just got out of rehab thankfully to be allowed to come to Florida for the winter. He will most definitely NOT be able to drive ever again, He is fighting wife about getting rid of tractors next year.
They have to wait through the winter to find out what VA is covering and how much they will have to cover for bills. Low to medium chance they have to sell farm.
Block the clutch, oh yes. Turn the tractor off to be sure when getting off. You bet I do now. |
| Mark6005
10-08-2012 17:10:52
70.225.175.70
| My 64 4000 acted the same several years ago finally would not engage at all. Went to shop for new pinion gear. |
| JMOR
10-08-2012 12:30:33
72.181.173.171
Re: Ford 4000 4 cyl gas Solenoid? in reply to soundguy, 10-08-2012 10:01:47
| Quoting Removed, click Modern View to see...and when checking "wires" be sure to include battery cables & terminals at both ends of cables. |
| soundguy
10-08-2012 11:14:24
173.104.216.187
| | could it be? it might. might also be a bad trans top switch ( check by placing tractor in neutral, blocking clutch down, then using a jumper wire to jump terminal on solenoid hooked to trans switch to ground. ) could also be wire connections. could be a bad power wire to switched hot connection on solenoid. could be solenoid itself or could be the starter. jump out power and test ground to solenoid.. the easiest to do.. etc..
| ScubaInstr
10-08-2012 11:32:34
72.37.249.164
Re: Ford 4000 4 cyl gas Solenoid? in reply to soundguy, 10-08-2012 11:14:24
| | Ok - Will do the ground test when I get home today. Question -> Why do I block the clutch down if it's in neutral? Thanks! Tommy D. |
| soundguy
10-09-2012 04:37:42
184.245.112.212
Re: Ford 4000 4 cyl gas Solenoid? in reply to ScubaInstr, 10-08-2012 11:32:34
| yup.. as another said.. blocking the clutch is just one more level of prudence in trying NOT to get run'd over.. :) |
| Steve Brussell
10-08-2012 11:58:26
74.39.164.90
| Block the clutch for extra pre-caution. Getting run over by your tractor will really ruin your day. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
