Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 4000 Parts Online
Re: Ford 4000
Ultradog MN
10-08-2012 04:38:22
Start with the basics.
Verify that you have a bright bluish white spark at the plugs that will jump a good 3/8".
Short or yellowish spark will not do.
Next check your fuel.
Remove the plug on the bottom of the carb and let gas wizz into a can for at least 1 full minute. It should not slow down or stop in that time.
10-08-2012 10:22:32
 Re: Ford 4000 in reply to Ultradog MN, 10-08-2012 04:38:22
I have never worked on the gas version but are the plugs in the same basic holes the injectors would be in on the 3 and 4 cylinder diesels?
Ultradog MN
10-08-2012 18:47:54
 Re: Ford 4000 in reply to davida, 10-08-2012 10:22:32
Yes, same location and same depth of holes where the spark plug washer or copper washer on an injector seats against the head.
They are different heads - gasser does not have the locations for injector studs cast in.
Valves, rocker arms and push rods are the same part #s between the two.
