Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 860 problem
[Return to Forum]
lme
10-05-2012 13:36:01
76.7.18.37
OK, been working on my 860, trying to get it running because my 8 yr old grandson wants to drive it. It hasn't run for about 15 yrs, it has always been inside. I bought it new in 1956 when I was i8 yrs old. It has no fire at the points so I used a jumper wire from the + on the bat. to the + on the coil and it started by using the button on the solenoid. The starter button does not work nor does the switch do anything, what do I look for now? Thanks for any help.
[Reply]   [No Email]
Royse
10-07-2012 17:46:37
69.36.49.151
 Re: 860 problem in reply to lme, 10-05-2012 13:36:01
The push button grounds the wire that is connected to it.
All you have to do is ground that wire.
Be absolutely sure it's in neutral or it will run you over.
[Reply]  [No Email]
soundguy
10-06-2012 13:32:28
173.104.82.103
god a good battery?
you mention jumping + from battery.
what aren't you telling us?
is this machien now wired negative ground?
is it 12v or 6v?
alternator or genny?
so.. you can hotwire coil.. have you tried bypassing safety start button.. in neutral, and clutchblocked of course?
[Reply]  [No Email]
lme
10-07-2012 06:17:01
76.7.18.37
 Re: 860 problem in reply to soundguy, 10-06-2012 13:32:28
OK, I had it wrong in my first post, I have a new bat. I have 6 volt, positive ground, genny. I jumped the Neg. battery post to the + on the coil, had fire at the points, it stared right up after sitting for about 15 yrs.by using the button on the solenoid. How do I bypass the safety start button? Thanks
[Reply]  [No Email]
soundguy
10-08-2012 05:42:16
184.245.195.54
 Re: 860 problem in reply to lme, 10-07-2012 06:17:01
if oem style solenoid, it wants ground to activate.. the trans top switch merely is interlocked with trans to only operate in neutral.. otherwise it just grounds that lil wire..
[Reply]  [No Email]
old
10-05-2012 13:45:29
209.86.226.27
If it runs hot wired then you have a bad ignition switch of a bad wire from the coil back to the battery. Jumper across the ignition switch and if that works the switch is bad if not then you have a bad wire or connection
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
