Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Ford 681 Select-O-Speed Questions
[Return to Forum]
Spencer P
10-04-2012 14:56:23
216.155.209.49
I recently purchased a 681 SOS (year=1960). Am rebuilding the engine and the transmission looks good. I have the necessary manuals (even got the owner"s manual) but still have a couple of questions.
1)There is a lever on the left side and just forward of the seat (lower on the transmission casting) marked on and off. Anyone know what it turns on or off?
2) The pull handle on the dash...I"m assuming that if I pull it out I disengage the PTO and with it in the PTO runs...right? (if I"m wrong...what does it do?) I originally thought this was to shift it to the higher PTO speed, but I found another lever on the transmission housing that I think (maybe) does that.
Many thanks for your input.
[Reply]   [No Email]
Larry NCKS
10-05-2012 12:34:54
174.250.162.101
 Re: Ford 681 Select-O-Speed Questions in reply to Ultradog MN, 10-04-2012 14:56:23
The PTO clutch is not used for ground speed. It is used for engine speed only. Since it is not engaged and really has no drving force, even thogh the PTO does tend to rotate under no load, there will be no damage to components for having the ground speed engaged.
[Reply]  [No Email]
Sean in PA
10-05-2012 09:14:34
71.224.102.32
 Re: Ford 681 Select-O-Speed Questions in reply to Spencer P, 10-04-2012 14:56:23
Larry, thanks for the clarification. My S-O-S is only the single speed PTO. I thought that the interlock was between the 2 levers. But between the the handle on the dash and the ground speed would work as well I guess if the handle on the dash isn't needed for the ground speed. So the PTO clutch isn't used for the ground speed either then?
What abut the large number of S-O-S tractors where the handle on the dash doesn't actually shut off the PTO properly when you push it in? Can the PTO shaft be connected to both the ground speed gear and the input shaft gear at the same time, and can't that cause damage?
[Reply]  [No Email]
Larry NCKS
10-05-2012 06:20:27
174.253.137.32
 Re: Ford 681 Select-O-Speed Questions in reply to Fordfarmer, 10-04-2012 14:56:23
This is not correct in my understanding, Sean. The position of the one lever has no bearing on the other. If the ground speed PTO is engaged by the rear lever, there is an interlock built in that should prevent the dash control from being pulled to the on position. The dash control has nothing at all to do with the ground speed operation of the PTO. It only engages the engine operated PTO clutch.
[Reply]  [No Email]
Sean in PA
10-05-2012 04:43:07
71.224.102.32
Larry has it right.
There are 2 levers on the side.
The lever toward the front of the tractor is to switch between the 2 speeds that are driven by the transmission input shaft and the PTO speed on these only vary based on engine rpms. It should have 3 positions. One is for 540 rpm, middle is "off" the last is for 1000 rpm.
The lever toward the rear is for the "ground speed" PTO mode, which is driven off the output shaft of the transmission and therefore varies its speed based on how fast the rear wheels are turning.
The 540/1000 rpm mode and the ground speed mode are setup so that you should not be able to engage one while the other is already engaged. In order to be able to engage the ground speed, you must put the other lever in the middle, or "off" position. Likewise, in order to move the forward lever out of the "off" position to either the 540 or 1000 position you must first put the ground speed lever into the "disengaged" position.
These levers configure what is going to drive the PTO, and sets up the gearing going into the PTO clutch. The handle on the dash is what controls the engaging and disengaging of the PTO clutch itself. As Larry said, pushing the handle on the dash all the way in disengages the PTO clutch, and pulling it out engages it.
[Reply]  [No Email]
Larry NCKS
10-04-2012 16:11:23
174.253.137.32
 Re: Ford 681 Select-O-Speed Questions in reply to old, 10-04-2012 14:56:23
1) This lever shifts the PTO from engine driven to ground driven. The PTO is driven by the rear axle in the ON position.
2)You have this backwards. In is disengaged. Out is engaged. Most of these PTOs rotate even when disengaged when there's no load on them.
If you have an operators manual, the answers to both your questions are contained therein! Might be beneficial to spend some time studying it! :wink:
[Reply]  [No Email]
Spencer P
10-04-2012 21:50:02
173.239.83.225
 Re: Ford 681 Select-O-Speed Questions in reply to Larry NCKS, 10-04-2012 16:11:23
Thanks for the info. I've poured over the owner's manual (at least what I have) and could find nothing...perhaps I overlooked something. That does clear up a few things. I'm a rank amateur when it comes to stuff like this. Once put together an old MG...but tractors are another animal all together.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
