TractorLinks.com
Show Parts for Model:
Re: Brake Cross Shaft
awhtx
10-03-2012 20:37:39
OK Glen, I know what you mean now. I don't see it in the parts diagram either. It must only be sold as part of the complete trumpet. I happen to have a pair of trumpets laying around. The hole in the trumpet is bored all the way through and what appears to be a bushing to you is actually a "freeze plug" or "expansion plug" to seal that hole. The inboard end of the brake camshaft rides inside the "cup" part of that plug. I cannot tell if that plug can be driven all the way through until it falls inside the rear end or if there is a flange to stop it from being driven all the way through. In the latter case would need to drill a hole in the center of it and use a slide hammer with a sheet metal screw end to pull it out of the hole.
Unless the cup part of the expansion plug is completely worn away and the brake camshaft is cutting into the trumpet itself I'd leave it alone. If there is some way you can take a photo of it with the cam removed post the photo here and I'll compare it to mine.
GlenIdaho
10-03-2012 21:16:53
 Re: Brake Cross Shaft in reply to awhtx, 10-03-2012 20:37:39
Thanks Alan, you have a good suggestion, just leave it alone! It looks to me that the bushing wear adds to the pedal sagging a little, not much but adds to it. I'd have to pull the the axle retainer out a little to remove the camshaft. I certainly don't want to have to pull the axle trumpets to mess with the plug. I couldn't find anything in the book about it. I guess I'll try to adjust the sagging pedal via brake adjustment and just live with it. Thanks for your help Alan, you're a good man.
