1957 Ford 850. The brake cross shaft bushings needs to be replaced. Haven't dug into it yet, just doing homework, I assume it can be removed by splitting it. Any other hints?
Also, the right brake pedal height is lower than the left. I understand wear on the brake shaft end that actuates the brakes is a possible reason for this. Will building up the worn areas be beneficial? Thanks in advance.
