How can you tap into the hydraulics on a 3000 without the add on control valve where the adapter plate is located.
I know how to tap into the hydraulics on the Hundred series without the control valve by tapping and plugging the hole under the adapter palte and then drilling and tapping an outlet hole in the adapter plate for the return line and using the test port for the pressure line. I've got that rigged on my 660. I need to do something like that on a 3000 three cylinder so I can operate a two spool valve on a FIL.
Thanks, Zane
Thanks, Zane
