| Ford Tractors Discussion Forum |
Topic: Help with 971 wiring problem
[Return to Forum]
| Author |
[Modern View]
| Sprouticus
10-03-2012 19:20:47
69.46.209.38
I am working on a 971 for a friend.I have switched it over to a 12 volt system with a one wire type alternator. I set it up with the diagram in the link. Last night I tried it and it seemed to work fine. Well today I got the gas tank and radiator all set and tried to start it and get it running. I turned the key on and hit the starter button and the starter motor would not stop turning even after I stopped pushing the button, I turned the key off and it still kept turning, so I had to quickly disconnect the battery. So what am I doing wrong? (Also I eliminated the amp light and used an amp meter instead.) Thanks in advance. |
| Sprouticus
10-03-2012 21:06:13
69.46.209.38
Re: Help with 971 wiring problem in reply to Sprouticus, 10-03-2012 19:20:47
| | Thanks for all the quick responses. Everything is new, battery, solenoid, wiring, bat. cables, resistor, key switch, starter switch and all the gauges. (The tractor was a real mess.) So yesterday it worked fine, hit the starter button and it turned over, when I released the button it stopped. Then today, augh! I wanted to pull my hair out. I just went out to the shed and tried to reconnect the neg. cable to the battery, to see what would happen. Whoa, a big arc snapped at me, so I guess you were right about the solenoid being stuck. So I looked at the package the solenoid came in. See the attached image. CHINA?!
So I dug through my box of extra parts I have accumulated and found a good old U.S.A. made solenoid so I will put that on tomorrow and let you guys know it turns out. |
| soundguy
10-04-2012 15:40:17
184.246.183.131
Re: Help with 971 wiring problem in reply to Sprouticus, 10-03-2012 21:06:13
| | ditto what awhtx said.. weak bats can arc weld contacts in a solenoid. post back |
| awhtx
10-03-2012 19:47:41
72.26.142.171
| Attempting to start an engine with a weak battery will sometimes cause the contacts inside the relay/solenoid to "weld" themselves in the closed position. |
| Royse
10-03-2012 19:33:06
69.36.49.151
Re: Help with 971 wiring problem in reply to Ultradog MN, 10-03-2012 19:20:47
| Sounds like the solenoid stuck.
Check if it has a push button on the bottom of it to manually engage.
If so, you can usually wiggle it and it will release.
I got a cheap one like this from TSC.
It stuck again later, so I ended up replacing it. |
| Larry NCKS
10-03-2012 19:32:51
174.253.132.53
| diagram looks good, except I'd wire the lights to the B+ side of the terminal block and not the switched side. That has nothing to do with your problem, however.
Three posibilities I can think of. Starter button stuck on or solenoid stuck on or solenoid to starter switch wire shorted to ground somewhere. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
