TractorLinks.com
Show Parts for Model:
Re: ignition switch on 631
old
10-03-2012 17:22:49
Not likely to be the switch that is bad but I can almost bet you burned up the points. Easy way to know for sure is open up the distributor by pulling the cap rotor dict cover and have a look see at the points. Any time the key is left on the points almost always burn and then you have not spark
Larharm
10-03-2012 17:31:25
 Re: ignition switch on 631 in reply to old, 10-03-2012 17:22:49
I had already pulled rotor cap and cover off that is how i checked for spark looks like may need new points or could the old one be cleaned and filed.
Could the coil have been damaged
36 coupe
10-04-2012 04:11:21
 Re: ignition switch on 631 in reply to Larharm, 10-03-2012 17:31:25
A Chrysler service bulletin said good quality points are too hard to file.Points get very hot in normal use,oxides form that insulate the points.I have cleaned the points with a pocket knife and got engines running.I favor a diamond file but the diamond particles do come loose from the bonding.
old
10-03-2012 19:31:51
Very likely the old points are burns to bad to file. As for the coil as long as the bottom of it is still flat it most likely is ok. But if the bottom of it is bowed out you may have to also replace it but I would not do so till you did the points
