| Ford Tractors Discussion Forum |
Topic: ignition switch on 631
[Return to Forum]
| Author |
[Modern View]
| Larharm
10-03-2012 17:07:59
97.122.225.199
forgot to turn the switch off and now no spark how do you check switch could i disconnect it the to coil and ground to see if have spark there. |
| soundguy
10-04-2012 15:47:22
184.246.183.131
Re: ignition switch on 631 in reply to Larharm, 10-03-2012 17:07:59
| as others said.. you may be able to clean and regap.. if they were cheap poiunts with a palstic rubbing block.. it may have melted.. so check that. premium set with a phenolic or nylon block probably survived.. |
| Royse
10-03-2012 17:44:24
69.36.49.151
Re: ignition switch on 631 in reply to Shaun Wallace, 10-03-2012 17:07:59
| They could be cleaned, filed and re-gapped, at least for a test.
Some say they don't last as long after they've been filed.
Do you have power to the coil and the points when they're open? As in battery voltage? |
| old
10-03-2012 19:38:48
209.86.226.34
Re: ignition switch on 631 in reply to Royse, 10-03-2012 17:44:24
| Once burned most points are so far gone that filing them will not do the job. I have pulled them off and used a bench grinder and made them work but a simple file job I have yet to make work if burned badly |
| old
10-03-2012 17:22:49
209.86.226.32
| Not likely to be the switch that is bad but I can almost bet you burned up the points. Easy way to know for sure is open up the distributor by pulling the cap rotor dict cover and have a look see at the points. Any time the key is left on the points almost always burn and then you have not spark |
| Larharm
10-03-2012 17:31:25
97.122.225.199
Re: ignition switch on 631 in reply to old, 10-03-2012 17:22:49
| I had already pulled rotor cap and cover off that is how i checked for spark looks like may need new points or could the old one be cleaned and filed. Could the coil have been damaged |
| 36 coupe
10-04-2012 04:11:21
66.186.169.176
Re: ignition switch on 631 in reply to Larharm, 10-03-2012 17:31:25
| A Chrysler service bulletin said good quality points are too hard to file.Points get very hot in normal use,oxides form that insulate the points.I have cleaned the points with a pocket knife and got engines running.I favor a diamond file but the diamond particles do come loose from the bonding. |
| old
10-03-2012 19:31:51
209.86.226.34
| Very likely the old points are burns to bad to file. As for the coil as long as the bottom of it is still flat it most likely is ok. But if the bottom of it is bowed out you may have to also replace it but I would not do so till you did the points |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
