Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 3910 transmission rattle
[Return to Forum]
mite-help
10-03-2012 16:56:04
70.196.11.172
with engine running & low-high in neutral, place other stick in any gear & i get a pretty serious sounding gear rattle @ idle-[800 rpm] bring speed up to 9-950, goes away, may be fine @ idle til shut-down & restart. no noise when both sticks engaged under load--maybe a whine i don't quite like--pretty much picking up engine harmonics i think, but something i don't believe i have run into before on this model diesel. looks like trans/hyd fluid on dipstick-correct i think]? picking up something from clutch assy possible or bearings/gears?--thanks for input--paul
[Reply]   [No Email]
RodInNS
10-04-2012 21:50:20
216.118.158.123
 Re: 3910 transmission rattle in reply to mite-help, 10-03-2012 16:56:04
What transmission? 8x2 crashbox or 8x4 syncro?
Rod
[Reply]  [No Email]
mite-help
10-05-2012 01:28:28
70.196.4.196
 Re: 3910 transmission rattle in reply to RodInNS, 10-04-2012 21:50:20
it is 8x2--
[Reply]  [No Email]
mite-help
10-04-2012 18:10:18
70.196.10.202
 Re: 3910 transmission rattle--update in reply to mite-help, 10-03-2012 16:56:04
well, more checking on the trans noise today--it's hard to discribe a noise-but it a pretty bad knock/rattle, running with lo-hi in neutral & shifting main stick in various gears, it is worse in 7-8 speeds. clutch is out, so that is all locked together-depress & noise goes away--pulled top cover & seem to have a lot of play in mainshaft assy.--prying back & forth i can hear that loud thump i believe i'm hearing running-gonna dig out my 3000 manual-[same trans i think] can't remember, believe the rear bearing is cone/cup & shim loaded.I know these things pick up the engine impulses, but this is way worse than that & does go away with more rpm--but i think i gotta open it up to cure it--
[Reply]  [No Email]
sotxbill
10-04-2012 07:04:17
99.42.196.210
 Re: 3910 transmission rattle in reply to Francisco Minte, 10-03-2012 16:56:04
normal...normal..normal..
the shafts will freewheel, the cluch disc will rattle as its free between the pressure place, the wine can be the hydraulics flow and safety valves..
so far you have describe a whole lot of tractors... sound will change will as the fluid changes and thins and thickens...
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
