13/16-16 oil filter threads?
souNdguy
someone help me out here.. oil filter threads for spin on adapter is 13/16-16 to fit the common fram ph8a motorcraft fl1a and other fitlers?
(quoted from post at 16:50:42 10/03/12) someone help me out here.. oil filter threads for spin on adapter is 13/16-16 to fit the common fram ph8a motorcraft fl1a and other fitlers?
epends on who's adapter.. WIX adapter #24755 uses filter #51050 with 5/8 X18 threads.
(quoted from post at 18:53:25 10/03/12) The filters that Soundguy specified require an adapter with 3/4"-16 threads.
hat is a true statement.
He said, "..oil filter threads for spin on adapter is 13/16-16.." and then mentioned filters that were 3/4 X 16. AND my point was/is, that there are several adapters around in this world and without knowing the adapter, you can't know what filter it requires. And he didn't specify any particular adapter.
appreciate it. It was my bad on the info... i was looking at an oil sandwich adapter. It specified 13/16-16 threads and then listed a bunch of filters.. one of them seemed to cross to a napa #.. from there i musta typed it in wrong or say it wrong and thought it was the common 1452/1515/fl1a stuff.
mucho appreciate the correct info.
