| Ford Tractors Discussion Forum |
Topic: Brake Cross Shaft
[Return to Forum]
| Author |
[Modern View]
| GlenIdaho
10-03-2012 12:21:47
75.174.121.91
1957 Ford 850. The brake cross shaft bushings needs to be replaced. Haven't dug into it yet, just doing homework, I assume it can be removed by splitting it. Any other hints?Also, the right brake pedal height is lower than the left. I understand wear on the brake shaft end that actuates the brakes is a possible reason for this. Will building up the worn areas be beneficial? Thanks in advance. |
[Reply] [No Email] | |
| awhtx
10-03-2012 12:50:56
72.26.142.171
Re: Brake Cross Shaft in reply to GlenIdaho, 10-03-2012 12:21:47
| Glen, You don't need to split the tractor to replace the bushings. The pedal should come off the shaft and then the shaft can be removed out the left side and the bushings replaced. Adjusting the "star" wheel inside the brake drum (adjusted through the back plate) often raises the pedal. If the brake shaft end is truly worn then yes, welding it up can repair it. Alan |
| GlenIdaho
10-03-2012 20:12:02
75.174.121.91
Re: Brake Cross Shaft in reply to awhtx, 10-03-2012 12:50:56
| Hi Alan, Sorry I wasn't clear and used the wrong part name. I was speaking of the bushing for the brake actuator camshaft. Tried finding in on the NH Parts site and picked the wrong part name. Not sure now from the diagrams what the part number is for the bushing. At any rate, its the bushing that is in the axle trumpet that the brake camshaft pivots in. I assume you must split it (the bushing) to remove it. Thanks again. |
| awhtx
10-03-2012 20:37:39
72.26.142.171
Re: Brake Cross Shaft in reply to GlenIdaho, 10-03-2012 20:12:02
| OK Glen, I know what you mean now. I don't see it in the parts diagram either. It must only be sold as part of the complete trumpet. I happen to have a pair of trumpets laying around. The hole in the trumpet is bored all the way through and what appears to be a bushing to you is actually a "freeze plug" or "expansion plug" to seal that hole. The inboard end of the brake camshaft rides inside the "cup" part of that plug. I cannot tell if that plug can be driven all the way through until it falls inside the rear end or if there is a flange to stop it from being driven all the way through. In the latter case would need to drill a hole in the center of it and use a slide hammer with a sheet metal screw end to pull it out of the hole. Unless the cup part of the expansion plug is completely worn away and the brake camshaft is cutting into the trumpet itself I'd leave it alone. If there is some way you can take a photo of it with the cam removed post the photo here and I'll compare it to mine. |
| GlenIdaho
10-03-2012 21:16:53
75.174.121.91
Re: Brake Cross Shaft in reply to awhtx, 10-03-2012 20:37:39
| Thanks Alan, you have a good suggestion, just leave it alone! It looks to me that the bushing wear adds to the pedal sagging a little, not much but adds to it. I'd have to pull the the axle retainer out a little to remove the camshaft. I certainly don't want to have to pull the axle trumpets to mess with the plug. I couldn't find anything in the book about it. I guess I'll try to adjust the sagging pedal via brake adjustment and just live with it. Thanks for your help Alan, you're a good man. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
