TractorLinks.com
Order Ford 5000 Parts Online
Re: 5000 ford questions
Brian Allen
10-02-2012 17:44:56
Mo
The clutch is damaged, time to split the tractor and replace the damaged parts.
Below are things that can be done to prevent another split in the near future.
1 Replace the main seal on the rear of the motor.
2 Replace the input seal on the transmission too, while you have it split.
3 That frost plug at the rear of the motor can leak as well, It could be changed while you have the flywheel off for re-finishing.
4 Have a good look at your ring gear on the flywheel too, repair any damaged areas in the teeth, so the starter can do its job.
Others will be of more help with the 3 PH
Brian
