Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 5000 ford questions
[Return to Forum]
Mo Jim
10-02-2012 17:11:43
75.13.142.241
Picked up a 67 ford 5000 8 speed diesel earlier this year and just getting around to working on it. Purchased at an estate sale was told the clutch was out. So before just jumping in thought I’d get some opinions. From what I can tell it’s a mechanical clutch. I can put it in gear no grinding without depressing the clutch pedal. That seems wrong to me unless it disengaged. Is it possible its just stuck? Any thoughts. Another odd thing is the 3 pt. It won’t go down with the control lever down. Put a ton of weight on it but wouldn’t budge. Then after just sitting it went down, but as soon as you start the engine arms came back up even thought control lever was down any thoughts on that.
[Reply]   [No Email]
RodInNS
10-02-2012 18:59:06
216.118.158.123
Re: 5000 ford questions in reply to Mo Jim, 10-02-2012 17:11:43
Hydraulic issue... I'd say the control valve is probably stuck. That's going to require pulling the lift cover and disassembling the valves in there for a good cleaning in varasol and see how everything works. It's also possible that it's not adjusted correctly. Be well advised to get a service manual and go through the setting procedure just to double check the settings.
Clutch.... could be that the center hub is torn free of the lining. Could also be a broken shaft in the transmission. Depends on what happened or how it was abused. Hope you didn't pay too much...
You need to pay very close attention to things when you split the tractor. If the clutch doesn't look bad you better look for another reason...
Rod
  [Reply]  [No Email]
jimf in mo
10-02-2012 18:54:15
75.13.142.241
thanks all for your thoughts. It is not dual power. I dont mind fixing things and love playing with the fords. I dont farm but have 90 ac. to play on. Have 2 NAA a 861,961 and a 64 4000. so I have my projects.
  [Reply]  [No Email]
Brian Allen
10-02-2012 17:44:56
142.169.215.28
Mo
The clutch is damaged, time to split the tractor and replace the damaged parts.
Below are things that can be done to prevent another split in the near future.
1 Replace the main seal on the rear of the motor.
2 Replace the input seal on the transmission too, while you have it split.
3 That frost plug at the rear of the motor can leak as well, It could be changed while you have the flywheel off for re-finishing.
4 Have a good look at your ring gear on the flywheel too, repair any damaged areas in the teeth, so the starter can do its job.
Others will be of more help with the 3 PH
Brian
  [Reply]  [No Email]
Ultradog MN
10-02-2012 17:30:48
174.20.253.54
Dunno about the lift arms. As Soundguy says unloader valve?
Clutch is a simple single disc affair but has a secondary drive off the back of the clutch cover to run the second shaft.
They are great tractors and if the rest of it is decent it's worth your time to learn and fix.
  [Reply]  [No Email]
soundguy
10-02-2012 17:22:04
184.247.39.200
single plate dry clutch..
independent pto.
stuck clutches usually mena it grinds to put it in gear even if clutch is pressed.
unloader valve must be stuck on hyds...
sometimes seller's lie or don't know on year.
she's not got dual power does she?
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
