Does anyone know how to check the voltage stabilizer located on the instrument cluster? I'm having trouble with my heat gauge reading a little high and think it might be bad.I replaced the voltage regulator this spring and replaced the big long battery with a smaller truck battery with high cranking amps. It starts great but when I started baling hay I noticed that the heat gauge was reading alittle high and ran out of gas once when my gauge was reading 1/8 th.Just wondering if any of these things would be a factor. I like to fix something instead of just throwing parts at it til its fixed, much cheaper and easyer on the nuckels.
Thanks for your input Joe C
