Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 8210 enginequestions
[Return to Forum]
not a ford mechanic
10-01-2012 08:27:35
206.72.24.56
i havent worked on many ford tractors. but how do i get the engine on tdc? i dont see any cover to take off the clutch houseing or any markings on front pulley? im replaceing head gasket. i also need to know the sequence of setting the valve lash as to which order i do them? our local store does not have a shop book on this tractor and the customer needs the tractor asap. so no time to order one. pls help. thanks. jc
[Reply]   [No Email]
RodInNS
10-01-2012 09:41:30
216.118.158.123
 Re: 8210 enginequestions in reply to not a ford mechanic, 10-01-2012 08:27:35
If you've got the injectors removed... I just knock the flux off a welding rod and drop it in the hole... roll the engine over until it's on TDC. Watch valve movement to see when you're on the compression stroke. With the injectors in place you can often find TDC by feeling the resistance to turning and when it hops past... back it up a bit, then roll it ahead to TDC again.
Of greater concern to me would be the torque sequence for the head bolts. The diagram would be most helpfull. IIRC you would start on the middle bolts between 3 and 4 then work in a circling x pattern moving out as you go. I think this was done in 2 stages. One at 90 and the final at 105-110.
I'd also make a point of chasing the bolt holes with a bottoming tap and cleaning them out well...
Also have the head checked for flatness... and the block deck if possible. Grinding, or at least lapping the valves wouldn't be a bad idea either depending on how they look.
Rod
[Reply]  [No Email]
not a ford mechanic
10-01-2012 10:29:04
206.72.24.56
 Re: 8210 enginequestions in reply to RodInNS, 10-01-2012 09:41:30
the ford dealer told me the head tourque was 120 then 160 flbs. are they wrong?
[Reply]  [No Email]
Bern
10-01-2012 19:51:26
66.218.203.74
 Re: 8210 enginequestions in reply to not a ford mechanic, 10-01-2012 10:29:04
110# for 1/2" bolts, and 160# for 9/16" bolts.
[Reply]  [No Email]
RodInNS
10-01-2012 13:23:35
216.118.158.123
Depends on the bolt size... What I gave is for a 1/2" bolt.
If the dealer looked it up in a manual I'd go with that.
Rod
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
