| Ford Tractors Discussion Forum |
Topic: ford 3000 temp gauge
[Return to Forum]
| Author |
[Modern View]
| joe201
09-30-2012 15:24:45
50.40.234.33
I've been baling hay with my 1973 ford 3000 gas tractor and noticed that temp gauge is running just in the red after 20 mins or so it doesn't get any higher than half way in the red. I've baled 2 fields about 1800 bales running like that. It has a electic sending unit I don't think tractor is runnig hot. If I stop and let it idle heat gauge goes down to about half way. I've cleaned raditor,i'm wondering if thermostat could be sticking?or water pump could be bad,tractor is running great and doesn't seem to be really running hot. The raditor is in great shape, is there something that I'm missing or should I put a mechical gauge on it?If so where do I put it on the motor? or what could I be missing? And what is the operating temp and could I put a 160 degree thermostat in it?Any thoughts or advice? Thanks Joe C |
[Reply] [No Email] | |
| RodInNS
09-30-2012 20:02:43
216.118.158.123
Re: ford 3000 temp gauge in reply to joe201, 09-30-2012 15:24:45
| It's probably the voltage stabilizer... but to be sure I'd make a point of checking the block temperature near the head on the right side of the engine with an IR heat gun. That ~should~ give about the most accurate jacket temperature on those engines with a gun. I wouldn't entirely rule out the possibility that it IS hot either.Rod |
| flyingace
09-30-2012 17:34:44
208.101.209.27
| Quoting Removed, click Modern View to see
I can't help except to say that my '66 3000 diesel is having a similar problem. I've put in a new water pump, thermostat and flushed the radiator. It goes into the red sometimes, but it just doesn't seem to be running hot. I can take the cap right off the radiator without gloves. And I did stick a meat thermometer in the coolant while it was in the red, and it was normal temp and even below. Besides that, the engine just doesn't seem hot. I'm convinced it's the sensor. the connections or the gauge itself. |
| joe201
09-30-2012 17:12:31
50.40.234.33
| I've had this tractor about 3 years and the heat gauge and fuel gauge didn't work last fall i put a new fuel gauge and temp sending unit and voltage stabalizer on I've noticed that the fuel gauge reads a little high but never noticed or payed much attenion to the heat gauge. The fins on the radiator are clear. What should the motor temp run? Thanks for all your info and thoughts I just don't want to burn up my motor. Last night I cut alittle over 45 acres with my 489 hay conditionor and the heat gauge run at the edge on red and on the long side its was up hill and on the up side the gauge slightly moved up the the middle and made the turn and down hill side went back to the edge of red.Cut like that for almost 3 hours and tractor seemed OK Thanks again Joe C |
| Bern
09-30-2012 18:14:58
66.218.203.74
Re: ford 3000 temp gauge in reply to joe201, 09-30-2012 17:12:31
| If your fuel gauge reads high, as well as your temp gauge, then it's your voltage stabilizer. End of story. |
| Ultradog MN
09-30-2012 17:25:38
174.20.253.54
| My Ag teacher in HS said a tractor should run at rated speed and HP all day, every day and not have a problem. Baler on a 3000 is probably at the top of it's effective range though I'm pleased to see so many bales behind yours as 3000 is my fav. Don't forget your nose. Not often a tractor can get away from me on the smell test. Whiff of steam or that sweet antifreeze smell gets my attention in a hurry. |
| Ultradog MN
09-30-2012 16:34:46
174.20.253.54
| Joe, A couple of thoughts; You say you've cleaned the radiator but did you shine a light into the rad from the fan side and look closely (from the front) at all the fins and tubes? You might also stick a meat thermometer down into the coolant in the top of the rad and check the temp that way. Would give you a better idea if it actually hot or the gauge is malfunctioning. An ounce of investigation can be worth a pound of guessing and two pounds of wrenching. Also, do a search here for "voltage stabilizer" There have been some good threads here in the past where Rod, Bern, SoTexas Bill and others have discussed the electrical values of the voltage stabilizer that you could check with a VOM. It could also be something like cleaning the little spade connector on the temp sender on the front of the head. A dirty connection there could give false readings somewhere else. I haven't been into the the electrics in the back of the tach so much like the fellows above have though I really ought to learn. One of my best friends is an electronics guru - fixes photographer's strobe boxes from all over North America in his basement - and I just ply him with beer and good conversation while he does it for me. He's one of the last vacuum tube guys around. Giant ones for heat treating. They fly him around some times to fix them. |
| JMOR
09-30-2012 16:17:18
72.181.173.171
Re: ford 3000 temp gauge in reply to rabbit, 09-30-2012 15:24:45
| Quoting Removed, click Modern View to seePlenty of options out there. Leave it alone if not having trouble & call the new needle position your "new normal". Run it with cap lose & see if it is boiling. Loosen cap after running...BUT, & repeat as many times as necessary, do this with gloves & very, very slowly & carefully & insert wife's cooking thermometer for a check. Safer, but not as accurate, look at radiator near top tank with an infrared thermometer. Try a new sender & see if it changes anything. No doubt there are more. None are perfect solutions, as removing pressure changes things, such as boiling point. Sure don't want to hurt yourself..ain't worth it. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
