3000 gasser - no oil pressure
Ultradog MN
Location
Twin Cities
No oil pressure!
Oh yeah, maybe if I start it :)
Just got this engine put back together. New rings, valve job and grind .010 under on the crank, etc.
Got it running this afternoon.
All I need now is some wheel and tires.
"Tractor caddy" aint such a good idea actually.
Once I get the wheels and tires on the tractor how do you get the blasted frame out from under it??
Doh!!
Either torch it out from under the tractor or winch the whole thing up onto the trailer and haul it down to the recycling joint and have them lift it off with their 5 ton bridge crane.
Ken and I talked about it. Probably will leave the caddy there and let them have it in trade for the lifting.
Keep the good, heavy casters for something? someday.
Yes this is the frame from a school tractor though this tractor is not one - just parts and pieces from a couple different 2/3000s.
I see a generator stand looking for a generator.
or
a water well pumping station.. just hook it up to the pump.
