Well the Red Cote treatment was not the problem. My tractor was running rough and I assumed that it was still rust in the fuel system. So, I changed the filter and it looked good, checked fuel to the pump and injectors and it was good. I then pulled the top off the pump( Cav) and it had some rust under the cover. Now I flushed the pump and cleaned it up and it still runs rough and quits. Looks like I am going to have to pull the injectors and hope that is the problem and hope it did'nt screw up the pump. Any good ideas would be appreciated as to how to clean the injectors, or anything else for that matter.
Thanks,
Ed1
Thanks,
Ed1
