Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 5 speed shifter
[Return to Forum]
Blindhawg
09-26-2012 16:44:26
184.46.51.16
Is this a common issue w/5 sp shifter? Woodruff keyway
wallowed out in top of shifter shaft. I can"t figure how to get it
out of transmission w/out complete dissasembly. For 2 cents
I"d weld the shift lever to the shaft and let the next owner worry
about it!!!
[Reply]   [No Email]
Keith Williams
09-28-2012 08:29:44
24.142.137.38
 Re: 5 speed shifter in reply to Blindhawg, 09-26-2012 16:44:26
Blindhawg,
People used to Braze stuff like that in the past?
Would that work here??
HTH
Keith
[Reply]  [No Email]
Brian in MA
09-27-2012 09:05:26
155.52.208.80
I'm not familiar with that tranny, but I second your opinion if you are serious and it can work, weld it and keep using it. Had a similar issue with a shift fork on a 2120 Ford tractor. I covered what I could with wet rags and welded the shift fork inside the tranny. That was 12 years ago and it is still working fine. It would have been a double split to replace it, didn t seem worth the hassle. Weld can be ground if it needs to come apart later.
[Reply]  [No Email]
DenisW
09-26-2012 19:51:02
24.23.51.61
My 5 speed was frozen. Got it freed up with 50-50 atf and acetone mixed in oil can so I could apply directly to rust spots. Drained old oil, put in 8 quarts diesel, magnet in the drain plug, drove around ranch for a bit to warm it up. Drained diesel and found woodruff key on magnet. Refiled with 80-90 gear oil.
DenisW
[Reply]  [No Email]
Hobo,NC
09-26-2012 17:12:55
98.17.83.160
 Re: 5 speed shifter in reply to Doug (OH), 09-26-2012 16:44:26
Blindhawg said: (quoted from post at 03:44:26 09/27/12) Is this a common issue w/5 sp shifter? Woodruff keyway
about it!!!
Only after it reaches 60 years old... Trans will have to come apart :cry: That equals more worn parts to replace that you do not want to here about...
This post was edited by Hobo,NC at 17:13:24 09/26/12.
[Reply]  [No Email]
Blindhawg
09-26-2012 18:03:28
184.46.51.16
 Re: 5 speed shifter in reply to Hobo,NC, 09-26-2012 17:12:55
Was going to replace perfectly good 4 spd to get the granny
gear of the 5 spd. In your opinion, would it be worth it for bush
hoggin, discing and plowing with a 600?
[Reply]  [No Email]
Dean
09-26-2012 18:12:44
152.216.3.5
 Re: 5 speed shifter in reply to Blindhawg, 09-26-2012 18:03:28
The lower first gear of the 5 speed is helpful for certain tasks but not slow enough for a roto-tiller.
More importantly, if the 5 speed is from a x6x tractor, and you swap in all of the associated parts you will gain live PTO.
Dean
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
