Phil9N3667
A friend of mine has a "75-"76 9700 Ford that he parked last fall and can"t get it to start back up, He had someone else look at it,pulled the injectors, had them tested(OK) and put back in. Fuel filters were changed and I pulled the side cover off of the pump (CAV) and found the rack travel limited due to rust on the shaft.Got it cleaned/freed up and the cold start advance will set like it should. Bled the fuel system out up to the injectors and still wouldn"t fire . Tried some starting fluid directly in the intake manifold and still wouldn"t light off. The engine has some 10,000 hours on it and I"m inclined to think there"s a wear problem here. He got a can of John Deere starting fluid and tried that- no dice. I know CAV pumps are notorious for getting air in a system and being hard to prime, but I"m thinking other wear issues here and I figure somebody here might could tell me something !! Thanks in advance, Phil.
