| Ford Tractors Discussion Forum |
Topic: ford 860 cranking amps
[Return to Forum]
| Author |
[Modern View]
| 64drivers
09-24-2012 10:53:36
166.147.123.33
I had a 1955 860 that has been converted to 12v. I just replaced the battery and now get absolutely nothing when I attempt to start. No clicks, nothing. I have checked the wiring and the ground and it all checks out. The only thing I can think of is maybe I purchased too small of a battery. This one has 360cca. What is the spec cranking amps for a 860? |
| Brad_bb
09-24-2012 18:56:04
12.161.8.178
Re: ford 860 cranking amps in reply to 64drivers, 09-24-2012 10:53:36
| A voltmeter is an essential tool any car or tractor guy should have. It helps you solve a myriad of problems. I just chased an ignition problem on my tractor and without it, would have never found the problem. You should have one at the very least for measuring battery voltage.
You can test your starter (to eliminate that as the problem) by connecting a known battery like from your car or truck with jumper cables to the starter (One to the starter post, and one to chassis ground). If it turns, that eliminates the starter. You can eliminate your new battery as the problem by connecting your car battery to the posts/battery cables using your jumper cables. connect the car battery in parallel. You know the car battery is good so if nothing happens again, you know it's not the battery. It's somewhere in between, possibly the solenoid. |
| 64drivers
09-24-2012 11:12:02
166.147.123.27
| I don"t have a voltmeter here, but am planning to bring one this weekend to check. All I have is a test light. Just put on new solenoid. Tractor will jump fine with barely a turn on the starter. |
| soundguy
09-24-2012 11:17:07
173.103.52.237
Re: ford 860 cranking amps in reply to 64drivers, 09-24-2012 11:12:02
| | new solenoid? always more to the story the OP never tells us :( did you by chance use a car solenoid and not a tractor solenoid? tractor solenoid wants ground from the tranny thumb switch. car solenoids like power on their coil wire. i'm guessing you bought the wrong part.. |
| 64drivers
09-24-2012 11:27:50
166.147.123.26
Re: ford 860 cranking amps in reply to soundguy, 09-24-2012 11:17:07
| Bought it from yesterdays tractor part store and is exact same model as one I took off.Just swapped the solenoid this morning with no effect on original problem. |
| old
09-24-2012 11:59:14
209.86.226.56
Re: ford 860 cranking amps in reply to 64drivers, 09-24-2012 11:27:50
| 360CCA is a tad bit small but shoot I have used lawn mower batteries to start tractors before and they worked just fine. Before doing the parts throwing at it take that battery and either try it in something else or take it back and have it checked. I have more then once came home with a new battery that was worse then the one I used as a core. Now days it is getting pretty common to get new parts that are not worth any thing |
| soundguy
09-24-2012 11:48:03
173.103.52.237
| if you can jump across it and it works, check it to make sure that it is pulling in when you ground the small tab |
| soundguy
09-24-2012 11:03:01
173.103.52.237
| | 360 cca is lekly fine on a 6v starter.. you are dealing with double the voltage.. that makes alotta wattage. dito what jmor said. recheck connections.. adn make sure bat is charged. whats volt meter across bat say when you try to start? it drop to 2v? or 0v? |
| JMOR
09-24-2012 10:58:38
72.181.173.171
Re: ford 860 cranking amps in reply to old, 09-24-2012 10:53:36
| Quoting Removed, click Modern View to seecca is not your problem.
Wiring & connections, not good replacement battery, bad starter come to mind. Start eliminating one by one, with jumper cables & other battery, etc. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
