Ford 4000 S.O.S. Creeping
I have a 1964 Ford 4000 with the S.O.S. that wants to creep forward in any gear except park with the inching pedal pushed down. With the pedal down and the selector in R1 it creeps forward till I release the pedal and then it will go in reverse but it pulls the engine down a little. I have another one and it never acts this way. The problem tractor only has 600 hours on it but it sat for twenty years in a barn before I got it. There was a lot of crud in the transmission so I flushed it out with new New Holland oil twice but it really didn't make much difference. I readjusted the servos and that didn't help either. Has anyone had this problem and found the fix? I could use the help.
I'd say the tractor that doesn't tend to forward creep is the abnormal one. There are enough driven components in these transmissions that they normally have a tendancy to want to pull forward.
Agreed.
This is the reason why I installed x00 brake locking mechanisms on my 64 4000 SOS.
Dean
Agree with the above. Was one reason I got rid of mine....had to shut off the tractor to hook up an implement.
Mark
(quoted from post at 08:42:44 09/25/12) Agree with the above. Was one reason I got rid of mine....had to shut off the tractor to hook up an implement.
Mark
My '73 4000 S-O-S creeps in just about every gear but Park until it's good and warmed up, but only if you don't apply the brakes at all. Even a light pressure on my brakes stops the creep. I put the brake lock on and get off with it in neutral without a problem.
Thanks for all the input from all you Ford guys. I did a little checking since my first post and also rechecked the bands. One thing I failed to mention the first time was that the engine would pull down so much in R2 when I release the inching pedal that it would kill it, R1 was a little less severe. The traction coupling was disconnected while I was running my tests. I checked all the servo pressures throughout all positions and all had either no pressure or around 185 psi as they should. So I don't think it is the bands. The clutches are the question, can they be warped and dragging that much to kill the engine in R2. Next I took the top off the transmission to inspect the valves to see if any were sticking and they were all functioning as they should.
The reason I think there is something wrong with this tractor is I have owned 5 SOS's and worked on several more and none seemed to creep as bad as this on does and I wanted to give this one to my son but I'm a little concerned it may be the wrong tractor for him with the creep and it being his first real tractor. I do have an 861 transmission setup I could put in it then let him have it.
Any other thoughts...
Yep! Rethink your bands. Band adjustment will have no bearing on servo pressure readings . . . unless it's way wacky, as in dropped a strut.
You've got a band or bands too snug on that tractor.
(quoted from post at 06:40:49 09/24/12) Agreed.
Dean
Do you have any photos or a parts list?
