Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 2000 gasser
[Return to Forum]
Mr Frank
09-23-2012 10:49:09
98.67.130.130
Well, got "big blue" busted off yesterday with my auxillary gas tank and rebuilt carb installed, runs fairly well, does sputter a bit when the throttle is opened, but if you pull choked it doesn't the fuel pump is unhooked and just gravity feeds from tank would that cause that? And also do I still need to use an orc when bushhogging??? thanks in advance
[Reply]   [No Email]
Sean in PA
09-24-2012 15:59:57
71.224.102.32
Re: 2000 gasser in reply to Mr Frank, 09-23-2012 10:49:09
12 forward and 3 reverse? Sounds like a 4 speed with a Sherman combo. Is there a single stick shift on top that has 4 forward and 1 reverse speeds, plus a handle down on the left side of the transmission that shifts between low, medium and high range? If that's what you have, then it's a transmission driven PTO, and yes, you need an Over Run Clutch (ORC) when running a bush hog.
  [Reply]  [No Email]
Ultradog MN
09-23-2012 11:07:28
174.20.253.54
When you mention fuel pump I assume you have a 3 cylinder model?
If you still have the holley carb it probably does require higher than gravity fuel pressure to operate properly.
ORC depends on whether you have live pto or not.
With lpto you don't need an orc.
  [Reply]  [No Email]
Mr Frank
09-23-2012 14:11:19
98.67.130.130
Re: 2000 gasser in reply to Ultradog MN, 09-23-2012 11:07:28
Don't know how to tell if I have live PTO all I can say is that the PTO does stop when clutch is pressed, but it doesn't have to be depressed to engage the PTO. Mostly what I have ever been on are N series. Thanks
  [Reply]  [No Email]
soundguy
09-24-2012 05:28:23
107.41.172.96
Re: 2000 gasser in reply to Mr Frank, 09-23-2012 14:11:19
you should be using the clutch to engage the pto.
with no load on the pto it will engage without the clutch.. but with a laod on it it will grind.
use the clutch
  [Reply]  [No Email]
Ultradog MN
09-23-2012 15:56:33
174.20.253.54
On a 2000 with lpto when you push the clutch halfway down the tractor will stop.
If you push it all the way down the pto will stop.
Tell us what speed your tractor has 4, 6 or 8
or better yet post all three lines of code that are stamped just above and aft of the starter.
Folks here will be able to tell you exactly what you have.
You might have to scrape off some paint to see them.
  [Reply]  [No Email]
Mr Frank
09-24-2012 14:38:03
98.80.56.164
Re: 2000 gasser in reply to Ultradog MN, 09-23-2012 15:56:33
I have the 12 forward 3 reverse transmission, which i might add might sound impressive to some, I can't imagine you ever needing to use anything other than low range, it is an extremely high geared tractor
  [Reply]  [No Email]
mr frank
09-23-2012 10:50:25
98.67.130.130
Don't think I'm important enought on here to be addressed as mister but this is a new puter and I don't know my password lol
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
