| Ford Tractors Discussion Forum |
Topic: Steering motor pouring out oil...
[Return to Forum]
| Author |
[Modern View]
| FordTractorMan
09-21-2012 19:23:16
50.40.230.188
A problem that developed within a few weeks of getting my TW35 home last spring was the steering motor leaking. It pours out oil nearly as fast as you can dump it in. Fill the reservoir plum full and you can run about 45 min before the steering gets a little tough. At an hour, you have no choice but to stop and add fluid. Some years ago, we upgraded the 8000's motor to the newer style. I took it off in '09 and replaced the seal. No problem getting it off the 8000. Looks more difficult w/the TW since it has a cab and there's more in the way of the it. Anyone done this? What's the best way to go at it? |
[Reply] [No Email] | |
| Bern
09-21-2012 19:43:12
66.218.202.178
Re: Steering motor pouring out oil... in reply to FordTractorMan, 09-21-2012 19:23:16
| | Gen II TW 35...oohh...not fun :-( You thought the wheel wedges were tough... Steering motor needs to come out - no other way around it. Remove whatever it takes to get the motor out, which may include: engine mount hydraulic pump, windshield washer reservoir, top engine hood, rear engine support bracket, etc. Before you remove the motor, find out EXACTLY where it's leaking, unless you want to replace every seal inside that thing. USUALLY they leak on the bottom cap, but they can leak out the top as well by the input shaft. Clean, and I mean CLEAN the motor as good as you can. You want NO dirt inside of it, or it WILL hang up. TORQUE the bolts to SPEC when reassembling, or it WILL bind up. Wonder why it leaks? Oil gets too hot. This is a common problem on the TWx5 series. It was never an issue on the earlier TWs, and it used to stump me until I thought about it hard. The TWx5 series tractors used viscous fan clutches; the earlier ones used solid fans. The solid fans pushed way more air than the viscous fans ever did, keeping the PS system cooler. If it was my tractor, I would plumb a cooler into the PS return circuit. I have done this on a TW25 that operated in a hot climate and had repeat issues with the steering motor leaking. |
| FordTractorMan
09-21-2012 20:57:36
50.40.230.188
Re: Steering motor pouring out oil... in reply to Bern, 09-21-2012 19:43:12
| Yeah, I can tell it's going to be a ball. I knew it had to come out, just wasn't sure if there was a specific step by step, or just move whatever's in the way. Appears to be leaking at the bottom. That's where the one on the 8000 leaked. Is retrofitting a solid fan an option? |
| Bern
09-21-2012 22:05:21
66.218.202.178
Re: Steering motor pouring out oil... in reply to FordTractorMan, 09-21-2012 20:57:36
| I think you could convert to a solid fan, but myself, I would simply add a small cooler. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
