| Ford Tractors Discussion Forum |
Topic: planetary drive
[Return to Forum]
| Author |
[Modern View]
| KGB
09-20-2012 10:40:57
107.1.77.118
I'm considering buying a NH 1495 haybine w/a planetary drive. What is a planetary drive and what advantages/disadvantages are associated w/these types of drives?" |
| Sean in PA
09-23-2012 05:24:17
71.224.102.32
Re: planetary drive in reply to 8N'r--WI, 09-20-2012 10:40:57
| Quoting Removed, click Modern View to see
showcrop, I had no idea what that model haybine was, so I went and looked at the New Holland parts site, and it's listed as "1495 Self-Propelled Haybine Mower Conditioner". It came with its own engine (200 Ford gas, 256 Ford diesel, or a Perkins 4.236 diesel) and either a planetary gear drive or a hydrostatic drive. |
| showcrop
09-23-2012 13:43:16
75.67.231.80
Re: planetary drive in reply to Sean in PA, 09-23-2012 05:24:17
That certainly helps to explain it! |
| Hobo,NC
09-21-2012 18:48:52
71.30.104.204
Re: planetary drive in reply to dmiller, 09-20-2012 10:40:57
| It does not have to be a automatic to have a Planetary drive :roll: :roll: :roll: :roll:... Planetary drives are used in rite many tractors that are not auto... |
| wisbaker
09-20-2012 13:05:19
207.118.134.25
Re: planetary drive in reply to KGB, 09-20-2012 10:40:57
| Even older- Model T Fords used planetary gears in the transmissions. I used several different types of planetary gear boxes in the plant when we needed deep reductions to drive shafts or augers. In my experience they are more reliable than herringbone set ups. |
| showcrop
09-20-2012 12:52:42
75.67.231.80
| I would guess that it is a step down to reduce the RPMs down from a 1000 RPM tractor. I have never heard of planetarys in themselves causing problems. Have you looked at it to see what the input shaft coupling is? |
| Dean
09-20-2012 12:03:30
152.216.3.5
| | Planatary gear systems have been around for well over 100 years, are mature technology and are used in just about all automotive/light truck transmissions as well as most modern farm tractors. Dean |
| Sean in PA
09-20-2012 11:51:49
71.224.102.32
| Planetary drive just means that there's a center gear (the sun gear), with multiple smaller gears around it (The planet gears) and an outer carrier with a ring gear around the outside of the planet gears, and the input to output gear ratio is achieved by locking or unlocking the sun, planet, and ring gears relative to each other. Most modern automobile automatic transmissions use a planetary gear system, as did the Ford Select-O-Speed tractor transmission, and the double reduction rear axle in the 1965 and later 4000/4600/5000/5600...etc. tractors had a planetary gear system as the final reduction out in the axle trumpets next to the brakes.
A planetary gear system isn't necessarily evil in and of itself.
I'm not familiar with the 1495 haybine, so I'm not sure exactly how the planetary gears are controlled to change the gear ratios on that model, but looking at the New Holland parts web site, it looks like it is a much simpler design than the Select-O-Speed transmission. there is only one planetary gear system in it, as opposed to 3 in the Select-O-Speed.
Hopefully someone who has actually had one for some amount of time will chime in and let you know how reliable they are and what you might need to look out for. |
| old
09-20-2012 11:24:10
209.86.226.19
| Same basic system as the older Ford SOS type of transmission. Me I would run not walk away from it but I do not like the SOS system or for that matter any type of automatic transmission |
| showcrop
09-22-2012 18:05:11
75.67.231.80
Re: planetary drive in reply to old, 09-20-2012 11:24:10
I've been tearing up and down the road trying everything I can think of. How fast do I have to get going in 5th before my SOS will automatically shift into 6th. Do I need to get the bands adjusted? |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
