| Ford Tractors Discussion Forum |
Topic: Ford 4000 serial number?
[Return to Forum]
| Author |
[Modern View]
| CK in MO
09-19-2012 15:46:29
98.22.52.125
I have a 4000 and have looked at most of the sites that tell how to read the serial number and production codes, here is my model number DA214C, none of the sites mention the "A" it should be a number if I am reading correctly, the tractor is a diesel, ag model, (I think), 8 speed trans, with independent PTO.Any help would be appreciated CK |
| Sean in PA
09-20-2012 05:09:17
71.224.102.32
Re: Ford 4000 serial number? in reply to CK in MO, 09-19-2012 15:46:29
| The B503646x is a Basildon, UK serial number, but I'm not sure of the x at the end. The B and A serial numbers were not well documented anywhere that I know of.
9D30 is April 30, 1979. The UK made tractors often seem to be missing the shift designator from the production code. |
| Sean in PA
09-20-2012 05:05:26
71.224.102.32
Re: Ford 4000 serial number? in reply to ohjeffoh, 09-19-2012 15:46:29
| Quoting Removed, click Modern View to see
No, a 4600SU model number would start with DS1 or DS2. |
| CK in MO
09-19-2012 16:27:17
98.22.52.125
| | The other numbers are, 9D30 seems to be missing the shift designator. B503646x I will have to look for pictures of the 4600 but it sure looks like a 4000 tin wise, there is no foil sticker under the hood either. Thanks for the quick help CK |
| mhb@ufe
09-19-2012 16:15:31
184.153.187.144
| DA2 = 4600 1 = diesel vert ex 4 = 540 Ind PTO C = 8x2 manual transIf it has the 3 piece swept back axle it is a 4600SU Mark |
| Sean in PA
09-19-2012 16:10:41
71.224.102.32
| DA2 as the first 3 characters of the model number means that it is a 4600, which was a little later model than the 4000. The 4600 was made from 1975 to 1981. The rest of the model number, 14C, matches your description of a diesel engine, independent PTO and an 8 speed transmission.
Post some pictures and we can help determine if the model number is correct. The numbers are stamped into the transmission housing, so if the transmission was ever swapped out, it would be stamped with the model number of the donor tractor.
What are the other 2 numbers that should have been found with the model number on the flat spot on the bell housing?
Also, check the under side of the rigth hood panel for a foil sticker. If it's still there, post those numbers as well. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
