TractorLinks.com
Order Ford 4000 Parts Online
1964 4000 Gas
R Pruitt
09-17-2012 11:52:08
Iím trying to put a new gage package on my 4000 and I canít locate the port for the water temperature fitting. I also would like to know if its permissible or recommended to blow out the oil pressure line leading to the gage. If so does it bleed itself or should I bleed it?
Dean
09-17-2012 12:22:15
 Re: 1964 4000 Gas in reply to R Pruitt, 09-17-2012 11:52:08
The temperature sensor port is at the extreme lower left corner of the cylinder head as viewed from the spark plug side.
Yes, you can blow out the oil pressure gage line if you like but I would recommend disconnecting it at the engine fefore doing so.
You need not bleed the air from the line but the gage will be more responsive if you do.
Dean
R Pruitt
09-17-2012 13:42:50
 Re: 1964 4000 Gas in reply to Dean, 09-17-2012 12:22:15
Thanks, Dean you got me covered....
