Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Front tires on loader
[Return to Forum]
DenisW
09-15-2012 15:01:34
24.23.51.61
Need to replace front tires on Ford 851 with Wagner loader. Tires are 6.50-16, 6 ply and rated load of 1610 lbs. Local tire stores, two of them, that deal in truck and tractor tires say they can get the 6.50-16, 6 ply with 1200 lbs load. I am thinking that 1200 lb load is not enough with loader. Has anyone else had this problem?
[Reply]   [No Email]
Royse
09-16-2012 17:38:50
69.36.49.151
Re: Front tires on loader in reply to Ultradog MN, 09-15-2012 15:01:34
Echoing Dean's comment.
If those tires won't hold up you shouldn't be there.
(pot calling the kettle black in my case)
  [Reply]  [No Email]
Dean
09-16-2012 16:54:04
67.172.15.77
Re: Front tires on loader in reply to DenisW, 09-15-2012 15:01:34
The 1200 lbs. load range tires are more than adequate.
Your front axle is not designed for such loads.
Dean
  [Reply]  [No Email]
crazylocha
09-16-2012 16:23:11
142.197.202.50
Appreciate all the advice. Am looking to replace the rims, just not sure about cheap availability of 16" tires for it.
Have some time to make mind up though.
Thanks all
Mikey
  [Reply]  [No Email]
old
09-16-2012 09:52:53
209.86.226.27
Also if you look in the archives I posted a couple pictures the other day of a 3000 ford that has extra wide tires on it because it does have a loader on it just not right now due to a bolt the broke off and I get the fun of fixing that problem also
  [Reply]  [No Email]
crazylocha
09-15-2012 18:15:48
142.197.202.50
Now what do you all recommend for my 74 3000 w/FEL.
Currently have 7.5X15 tri rib on one side, truck tire making do (w tube) on other. Both rims are pretty crappy, lots of welds and bunch of rust. One of the things up for changing out when I get her split is those rims.
Suggestions on size?
  [Reply]  [No Email]
old
09-15-2012 21:34:11
209.86.226.32
Re: Front tires on loader in reply to crazylocha, 09-15-2012 18:15:48
You can go back with the 15 inch rims and tires and then use good used truck tires like I do or go with the 16 inch rims and do the same thing. If you have the trouble with clay just use the All terrain type tires.
  [Reply]  [No Email]
Fordfarmer
09-15-2012 21:21:56
98.125.120.200
If you're replacing the rims as well, go up to 16". Then you can get cheap (free, some places) used load range E pickup tires, if that's what you want to run. I don't run them, or even multi-ribs on my loader tractor, as I'm in clay, and any time it gets wet, I need the extra steering traction a 3-rib gives. 3-ribs work better when that tractor is on the mower, too. Go with 8-ply. That will be heavy enough for a 3000 (or a 4000 SU) with a loader. Probably 7.50's... any wider and they may not clear your spindles. I'm probably going to step up to 10 ply on my 4600... I've ruined too many 8-ply when I'm loading high moisture bales and 5'x6' dry bales...
  [Reply]  [No Email]
soundguy
09-15-2012 17:19:03
173.104.46.186
on my 850 with superior loader.. i run truck tires.
on my other loader tractors.. I tossed the tri ribs and went to multi ribs.. 8ply minimum.... 6.5-16
  [Reply]  [No Email]
Ed H.-OH
09-15-2012 17:10:19
72.23.247.131
Hello, I agree with old, Mine has 8 ply truck tires. You can lift 1500 pnds. and the tractor never moves -ed
  [Reply]  [No Email]
old
09-15-2012 15:12:33
209.86.226.56
On my 841 I use truck tires that are 235/75R-16 radials and have done so for years. The sit wider and flatter so with the loader I have keeps it form digging in in soft ground and also works well on snow
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
