We have just purchased a Ford 5000. Unfortunately the independent PTO does not operate although the seller said it was working. I have fitted a pressure gauge to pressure point on RH side of rear transmission housing. It reads 40 to 60 psi depending on revs. Book says it should be 130psi or more. Does this mean pump is poor. How much trouble to remove and repair? Can you remove the dual hydraulic pump on 1971 Ford 5000 without removing the lift cover? This tractor also has no power steering operational. It appears that the oil reservoir is leaking oil via the pump seal into the engine oil. You can see the level dropping after filling. Would a leaking shaft seal cause complete pressure loss in the steering. I am looking for a good exploded view of the steering pump and PTO and hydraulic pump that suits this model. The repair manual I have is printed in 1968 and some items appear to be different. Thanks.
