Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 575E Ford Backhoe wont turn over
[Return to Forum]
Mel917
09-11-2012 17:50:53
72.152.157.145
304-4 diesel engine barley turns over. Has new battery, new starter and cables. Once you get it started it runs like a champ and has no unusual noises. Has progressively gotten worse over the last 2 years. I have put multiple commercial NAPA 925 amp batteries in parallel to make sure I have enough cranking amps and has not helped at all. Anybody have any ideas?
[Reply]   [No Email]
Mel917
09-12-2012 08:13:14
75.144.236.219
Re: 575E Ford Backhoe wont turn over in reply to Mel917, 09-11-2012 17:50:53
Thanks for the replies. I will try the voltage drop on the cables to see how the connections are but I have hooked the battery directly to the starter solenoid and ground to the bolt on end of starter housing with no luck. If all is good on voltage drop I will probally get another new starter, maybe this one is defective even though it is new. Has any one ever heard of an engine being to tight for the starter to turn it even though it is not a new engine??
  [Reply]  [No Email]
Bern
09-12-2012 08:51:20
66.218.203.246
Re: 575E Ford Backhoe wont turn over in reply to Mel917, 09-12-2012 08:13:14
YES! If something is causing the hydraulic pump to go up against relief, it will make it very difficult for the engine to crank over. To test for this, start the engine and roll the loader bucket all the way up against the stop - you should hear the engine lug when the cylinder bottoms out. Shut off the engine. Continue to hold the loader control valve in the roll back position while cranking the engine. If the engine cranks the same as "usual", then I'd say something is causing the system to go up against high pressure relief. If the engine cranks even harder than normal, then my theory is not your problem.
  [Reply]  [No Email]
Mel917
09-17-2012 07:13:06
75.144.236.219
Re: 575E Ford Backhoe wont turn over in reply to Bern, 09-12-2012 08:51:20
Thanks for all the tips. I have located the problem. I sould have checked this sooner but had a brain malfunction I guess. I had no current to small solenoid wire and found that a rat had chewed the wire just about 6 inches away from the starter relay in engine compartment. Repaired the wire and it starts with no problem now. Again thanks to all for the help.
Mel
  [Reply]  [No Email]
RickB
09-12-2012 02:53:00
68.237.141.55
Cables are notoriously problematic on these machines, especially those with the two battery option. Does "new cables" mean ALL new cables? How about a resistance test of the disconnect switch and a close check of the connector post where the three positive cables meet?
  [Reply]  [No Email]
RodInNS
09-11-2012 20:39:09
216.118.158.123
I'd probably make a point of checking the ground connections/path to the starter. I'm not entirely sure how that is on the backhoes... but I suspect it goes to the frame somewhere. Check that connection. Also check for a clean connection between starter and bellhousing...
Cables... if they're not OEM... make sure they're soldered on both ends. Bolt on cable ends aren't worth a damn....
Beyond that... I'd look at the starter again. Could be brushes, bushings or the contacts in the switch.
For what it's worth I've got one that is somewhat weak like that. I still haven't figuered it out... but it's not too bad either....
Rod
  [Reply]  [No Email]
soundguy
09-11-2012 18:06:44
173.104.130.107
do you have a battery ground to the starter?
bat cables good with no corrosion in them?
my 7610s has a 304 in it... and it likes clean cables.
if your cables are good. check the wire connections to the starter itself.. past that may be time to pull it to check for bushing wear.. that makes em strain bad and puts the shaft in a side load bind.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
