| Ford Tractors Discussion Forum |
Topic: NAA steering
[Return to Forum]
| Author |
[Modern View]
| Nilram
09-10-2012 08:16:39
208.123.15.242
I have a NAA that I'm trying to put back together(the parts came to me in a box) When I poor the lube into the fill hole on the steering sector it appears to flow into the tranny. Is there a plug or something that is suppose to prevent this from happening? I plan on filling the sector with grease but I don't want it to drop into the tranny as well. Thanks for your help |
| Larry NCKS
09-11-2012 17:17:21
75.88.101.196
Re: NAA steering in reply to RTR, 09-10-2012 08:16:39
| I turned another year older today, but guess I'm still not too old to learn a thing or two. :lol: |
| Billy OK
09-11-2012 09:07:22
67.67.11.151
Re: NAA steering in reply to Nilram, 09-10-2012 08:16:39
| | Hey now I just redid my 860 this weekend.I sealed everything up with the form a gasket left over from my F250 differential lube change.Its grey colored stuff.Fluid can only get out threw a welsh plug from the very bottom,sector shaft seals,or sector shaft cover plate,or from the steering shaft tube where it bolts onto the steering box. I put RTV on the welsh plug,rtv on each mating surface of the shims,and also installed new orings on the side covers,and new sector shaft seals. If it still leaks go to john deere and get corn head grease,and pump the housing full 3 tubes I think. I still have the corn head grease handy but,havent used it yet. I discovered my steering box leak replacing the oil pan gasket. Billy |
| Kurt-NEPA
09-11-2012 06:26:52
70.44.245.96
| My 5 speed 660 is the same as soundguy posted. Leakage will go into the bell housing, or down the side of the tractor if it comes out along the sector shafts. |
| soundguy
09-11-2012 12:15:15
184.246.9.9
Re: NAA steering in reply to Kurt-NEPA, 09-11-2012 06:26:52
| | i'm pretty sure all 8n, naa, and 00 and straight gear 01's are like that. i've had the steering boxes off 2 5spd rowcrops while messing with that funny thrust bearing adjustment nut, and don't recall seeing tranny gears where the input shaft should be.. :) soundguy |
| Larry NCKS
09-11-2012 06:02:24
70.198.1.185
Re: NAA steering in reply to Mad Farmer, 09-10-2012 08:16:39
| You know my experience is mostly with the best transmission Ford tractor built in the late 50s, 60s and 70s - the SOS!!! :lol: I also have a little on what I call the Monkey Shift, more commonly known as the 5 speed.
On the SOS the sector closes the transmission itself. I'm thinking the 5 speed does as well. It does appear that I'm in error on the 4 speed, however. My apologies. :oops: |
| Larry NCKS
09-10-2012 18:22:02
70.198.2.190
Re: NAA steering in reply to showcrop, 09-10-2012 08:16:39
| Prior to 1/59 CNH parts shows this to be an expansion plug and says to procure locally. Beginning 1/59, during the production of the 01 series, it changed to a 3/8-18 threaded plug. Therefore, you need to get a measurement (I'd take a wild guess and say it's likely 3/8 as well) and go to your favorite auto parts store and get one.
The guys are in error about any sector leakege going into and out of the bell housing, You are correct that it will leak into your transmission. |
| soundguy
09-11-2012 05:48:43
184.4.146.28
Re: NAA steering in reply to Larry NCKS, 09-10-2012 18:22:02
|   Uh.. larry.. could you explain how oil leaking out of the bottom of the steering box is going to go into the tranny.. and not the dry area of the bellhousing. here is a pic of a rowcrop mind you.. but the trans castings from the 8n, naa, 00/01 series are cast the same way.. ie. cavity ahead of the trans. 1st pic shows the box atop the trans.. notice the sherman shifter DIRECTLY under the steering box. we both know the sherman lives inthe place the input shaft used to live.. IE.. OUTSIDE and ahead of the tranny. 2nd pic is of an 8n trans I have in the barn. notice the trans cavity.. and thent he clutch bellhousing cavity.. and that the steering box sets above that empty cavity. hard to see how a drained steering box is gonna run into the tranny??? |
| soundguy
09-10-2012 11:42:29
173.104.61.240
| ditto what kurt said. you may have a perforation under the wormshaft where it rides in the thrust beairng and race.. |
| Kurt-NEPA
09-10-2012 08:29:54
70.44.245.96
| I think the NAA has a plug on the bottom of steering gear. I know my 660 does and I think they use the same steering gear. Is it there? If not, the oil will drop into the bell housing and come out the drain hole on the bottom (the hole with the cotter pin). The oil should not be getting into the transmission. |
| 36 coupe
09-12-2012 05:55:15
66.186.169.176
Re: NAA steering in reply to Kurt-NEPA, 09-10-2012 08:29:54
| Welsh plug in the bottom of the steering box.You could force the plug out pumping grease in.Should come out the top of the steering column first.Heard of a fellow who pumped a full tube of Grease into the water pump of a Model A Ford.The welsh plug could rust out if water got into the steering box.It can happen if the steering shaft is worn and the steering wheel skirt dosent cover the top of the steering tube. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
