| Ford Tractors Discussion Forum |
Topic: ford 5000 brakes
[Return to Forum]
| Author |
[Modern View]
| mjp
09-08-2012 17:34:05
71.235.124.165
has anyone replaced the brakes in a 72 ford 5000? where can i find a step by step video? |
| RodInNS
09-08-2012 18:08:39
216.118.158.123
Re: ford 5000 brakes in reply to mjp, 09-08-2012 17:34:05
| I've never changed the brakes on a 5000 specifically but I've had various others of the same design apart... Basically... remove your fenders/roll bars/lift arms/wheels and support the tractor on cribbing under it's center housing. Unhook the brake linkages after you back the adjusters off... then you need a crane or loader or some type of sling to support the axle trumpetts because they weigh several hundred pounds each. When supported... remove the ring of bolts that hold the trumpett to the center housing. Don't forget the bolt that is accessed through the lift arm hole... then as you take a bit of weight on the lifting device... gently slide the axle straight out until the sun shaft clears the differential. ALSO REMEMBER... the differential is fitted to the right side of the axle center housing and when you remove the axle trumpett it CAN DROP on the ground. So be quick to support it in place or be ready to remove it. Probably best to have a helper for this job (if they're the helping type vs the hindering type)... otherwise with a bit of experience it can be done alone. When you get the trumpett off... stand it upright on the axle flange... then you can look inside and see the brake parts. Remove the bolt ring retaining the brake housing and lift it out... pull the brakes out... inspect, etc. At a minimum you'll probably change the ceramic and intermediate plates and possibly the actuators as well depending on the wear. Sometime it's also necessary to change the inner and outer housings if they're worn past spec... I would suggest you consult the Ford service manual for those wear specs and also for the housing torque values. Assembly is in reverse of taking it apart. Be sure to change the boots on the brake actuator rods. Rod
| soundguy
09-10-2012 06:30:15
184.245.116.112
Re: ford 5000 brakes in reply to RodInNS, 09-08-2012 18:08:39
| mjp
09-09-2012 10:31:44
71.235.124.165
| I was afraid you would say all that. thanks |
| RodInNS
09-09-2012 10:49:44
216.118.158.123
Re: ford 5000 brakes in reply to mjp, 09-09-2012 10:31:44
| | It's actually a pretty simple job as repairs go on those things. If there's no roll bar... it's a whole lot easier. I've pulled those axle housings in under an hour on a 7710. Rod |
| Bern
09-09-2012 13:02:42
66.218.203.73
Re: ford 5000 brakes in reply to RodInNS, 09-09-2012 10:49:44
| Rod is right. The biggest pain is usually corroded rollbar and/or fender attaching bolts. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
