Topic: 841 PTO Question
[Return to Forum]
| Author |
[Modern View]
| ARHunter
09-07-2012 05:11:18
24.119.244.114
I retrieved the old bush hog I inherited from my dad a few years ago. It is still in good shape considering it is about 50 years old and has been sitting outside the whole time.
The drive shaft was just laying on top of the bush hog. It doesn't have an over-running clutch, but I assume it is a good idea to put one of these on since the tractor is a 841. Also, which end of the shaft goes to the tractor PTO shaft? One end has about a 1" square shaft that slides into the big round shaft, I assume this end goes to the bush hog gear box, but I'm not sure. Thanks for your help. |
| Sean in PA
09-07-2012 06:01:52
71.224.102.32
Re: 841 PTO Question in reply to ARHunter, 09-07-2012 05:11:18
| That telescoping mechanism (one end sliding in to the other end) is just to account for the varying distance between the mower's gear box and the tractor's PTO shaft as the mower moves up and down on the lift.
Most newer PTO drive shafts like that have a plastic cover around it that also telescopes, and can stay stationary as the shaft turns inside of it. This is for safety reasons, and if you have that plastic cover, it shouldn't matter which end you attach where.
If you don't have the plastic safety cover, I would put the end that has the round outer surface toward the tractor, and the end that has the smaller square shaft that slides up into the round section back toward the mower. This is so any brush, rocks or dirt that the shaft encounters as you are driving forward won't have the tendency to go into that hole that the inner shaft slides into. |
| ARHunter
09-07-2012 05:29:04
24.119.244.114
Re: 841 PTO Question in reply to old, 09-07-2012 05:11:18
| Quoting Removed, click Modern View to see
Maybe I didn't describe the shaft very well. It is 1 3/8" 6 spline coupling on each end. One end of the drive shaft has a 1" sqaure shaft that slides back and forth into the round shaft I guess to compensate for the change in distance as the bush hog moves up or down. I don't know if this end of the drive shaft goes to the tractor or the bush hog gear box. |
| Dave H (NY)
09-08-2012 05:07:04
184.20.161.214
Re: 841 PTO Question in reply to ARHunter, 09-07-2012 05:29:04
| Ok, if I understand your description....the shaft has a 1 3/8 splined coupler on both ends. The hog gear box also has the same 1 3/8 male end like the PTO. You want to know if the thinner end or fatter outside end face the tractor.... If I'm understanding you the answer is the thinner shaft end is the tractor side the larger side is on the hog and the tractor end slides in towards the hog. |
| old
09-07-2012 09:11:22
4.244.81.245
| One end of the shaft should have a simple bolt hole in it the other end a button you push to let it be slid on. The bolt hole goes to the hog and the other to the ORC that you for sure want to have. If it is the type with only the holes on each end the solid square part goes in the tractor and the tube part to the hog |
| Larry NCKS
09-07-2012 05:17:46
64.254.59.123
Re: 841 PTO Question in reply to Jerry/MT, 09-07-2012 05:11:18
| You definately want an ORC on that unit, or your tractor will go places you don't wish it to go.
Your assumption as to which end goes to the Hog is likely correct. However, that should be self evident as you observe the gearbox on the Hog. You know for certain that a square end won't fit your tractor PTO! |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
