| Author |
[Modern View]
| Danny P.
09-06-2012 05:49:05
170.141.177.87
I purchased a carb kit from this website for my m/s tsx 428. It has a rubber cup and a little white packing that I'm not sure were they go. The rubber cup is different on one side so I don't want to put anything in wrong and have to take it back apart. The instuctions don't have any sort of diagram and they aren't very detailed. It had alot of washers along with the parts I metioned above. When I tore down mine it didn't have all of those or they have desentigrated over time. Can some one post a good diagram or instructions? Thanks. |
| Royse
09-06-2012 17:17:38
69.36.49.151
Re: Jubilee carb in reply to 30_Eric, 09-06-2012 05:49:05
| Larry NCKS
09-06-2012 16:56:49
64.254.59.123
Re: Jubilee carb in reply to Ultradog MN, 09-06-2012 05:49:05
| it worked. you should have gotten a reply :lol: |
| Royse
09-06-2012 16:37:39
69.36.49.151
Re: Jubilee carb in reply to RodInNS, 09-06-2012 05:49:05
| Quoting Removed, click Modern View to see
Larry, I see yours as open and just sent you a test email from Modern view. |
| Larry NCKS
09-06-2012 16:27:27
64.254.59.123
Re: Jubilee carb in reply to So will the front axel, 09-06-2012 05:49:05
Old, I wonder if email works like it should on this site. I've had people tell me they can't find mind either, which is always open on Modern View as I see it.
I tried yours. Classic says you have no email listed and it will send me a message that you don't if I click on it. |
| old
09-06-2012 10:23:18
209.86.226.40
Re: Jubilee carb in reply to Danny P., 09-06-2012 05:49:05
|  Instruction sheet this is not the exact carb but is very close. I have the info on the correct carb also but will need to scan it in |
| old
09-06-2012 08:45:56
209.86.226.32
| My self I use the Walker brand carb kits that I buy from my local O'Reilly's. they have good instruction and also are not all that bad at around $20. I have a couple of the instruction sheets in the computer so it it would help drop me an e-mail and I can send you what I have |
| Danny P.
09-06-2012 10:07:18
170.141.177.87
Re: Jubilee carb in reply to old, 09-06-2012 08:45:56
| Thanks Old. Anything you have I would appreciate.danny.prosser@tn.gov |
| BruceR TN
09-06-2012 16:11:50
74.34.108.67
Re: Jubilee carb in reply to Danny P., 09-06-2012 10:07:18
| Danny, Where in TN are you located? I'm in Powell. |
| Danny P.
09-07-2012 05:33:34
170.141.177.87
Re: Jubilee carb in reply to BruceR TN, 09-06-2012 16:11:50
| I'm in Memphis. What part of the state is Powell located? |
| BruceR TN
09-07-2012 15:41:22
74.34.108.67
Re: Jubilee carb in reply to Danny P., 09-07-2012 05:33:34
| old
09-06-2012 10:13:37
209.86.226.40
| I can not send it to you by you giving me your e-mail address you have to send me one first since the safe mail system will not let me add thing. If on classic just click on send e-mail in the bottom right of this box and that will do it |
| soundguy
09-06-2012 05:52:58
173.107.232.190
| sounding like throttle shaft and choke seal / packings. |
