| Ford Tractors Discussion Forum |
Topic: 7710
[Return to Forum]
| Author |
[Modern View]
| ken tudor
09-04-2012 15:26:53
166.249.140.31
i am buying new injection pump minmex is the make of it. if i take it off can i bolt the other one back up an not have to time it. an how do u time this motors i no that with the other type pumps u take 3 bolts lose an turn from top dead center either way 10%.but the minmex pump times diffently can anyone help me with this.(the timming might be whats wrong with it an pump might be good). |
[Reply] [No Email] | |
| Tx Jim
10-10-2012 03:03:22
67.142.163.27
Re: 7710 in reply to Jack L. Massimino Sr., 09-04-2012 15:26:53
| Leaking fuel return lines will make a "mess" but not a "miss". Sounds as if it's a timing problem,bad injector or faulty engine cyl head valves. |
| sotxbill
09-11-2012 06:25:16
99.42.196.210
Re: 7710 in reply to old, 09-04-2012 15:26:53
| Quoting Removed, click Modern View to see
Ken, would run some really good injector cleaner through it as well..
I prefer bg 44k injector cleaner myself. Then you'll be good for another 40 years or so. |
| RodInNS
09-04-2012 20:28:18
216.118.158.123
Re: 7710 in reply to ken tudor, 09-04-2012 15:26:53
| There will be a dowell on the gear. As long as you don't remove the gear from time... you just unbolt the gear from the pump and remove the pump. IIRC, those gears are slotted to give the final timing adjustment... This is done by looking in the timing window on the front of the flywheel housing under the starter... as well as a timing locating pin on the rear end of the pump cam shaft. You set it so that the pointer on the pump shaft points at a mark on the body while bringing the flywheel around to the specified advance...BEst advice... get a manual for the tractor and review the procedure yourself and get the correct spec from the manual because I don't remember it with certainty off hand. Rod |
| Bern
09-04-2012 21:14:18
66.218.202.219
Re: 7710 in reply to RodInNS, 09-04-2012 20:28:18
| No dowel on the gear for an inline pump Rod. A person could get the timing way off and not have a clue. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
