Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: ford serial #
[Return to Forum]
seeblackcats
09-01-2012 17:57:43
161.216.8.6
I have a ford 3 cyl diesel tractor, when I got it I was told it was a 1975 ford 4000 but I when I went to get a part for the simms p4665 fuel pump the parts were not the same. So the ford dealer told me were the serial# was located on the tractor. the serial # is C192761 the serial number web pages don"t make sence to me can some help me please
[Reply]   [No Email]
Sean in PA
09-03-2012 04:55:48
71.224.102.32
 Re: ford serial # in reply to seeblackcats, 09-01-2012 17:57:43
See my reply to your other post. You have a 1968 3500, which is the industrial chassis version of the 3000 series, so it should have a Simms pump.
[Reply]  [No Email]
seeblackcats
09-02-2012 08:21:04
204.101.239.35
I will look for the other numbers. but the piece that broke is a bango fitting on the back of the simms pump. the problem is I can't see were it goes to or is it just an over flow.
Thanks
[Reply]  [No Email]
trac1
09-02-2012 05:27:22
50.88.28.69
A Simms P4665 pump is a 3 cylinder inline pump used on the 3000. What kind of part are you looking for? That might tell a lot about what tractor you have.
[Reply]  [No Email]
Sean in PA
09-02-2012 04:39:56
71.224.102.32
Ultradog is correct. The '65-'75 3 cylinder 4000 only used the CAV pump. The 3000 was the only model during that time that used the Simms pump, and only from 1/66 to 8/69 and again from1/70 to 12/70. So nothing used a Simms in 1975.
Your serial number of C192761 should be a 1967 serial number, but they assigned the serial numbers sequentially to each tractor that came off the assembly line, no matter which model it was, so it could have been a 2000, 3000 or 4000 series.
Since the serial number is from 1967, and you say that it has a Simms pump, then it may be a 3000 with a Simms pump. Post the other numbers as Unltradog said, and we can tell you what it was when it left the factory. Pictures would help as well, because if your numbers are only stamped into the transmission bell housing, the tranny might have been swapped out over the years, and if that's the case pictures and casting numbers may be the only way to identify it. A picture form the front showing the front axle and steering linkage, plus another from the right side showing the side of the hood and the injector pump would be the most helpful to get started .
This post was edited by Sean in PA at 04:42:25 09/02/12.
[Reply]  [No Email]
Ultradog MN
09-01-2012 18:27:40
70.57.147.217
There are 3 lines of code where you got that number from.
Either from a foil sticker under the hood or stamped into the tranny just aft and above the starter.
Post all 3 numbers and someone here will help you definitavely ID your tractor.
I thought all the 4000s had a CAV rotary pump and not a Simms. Some of the early 3000s did have inline Simms.
Others here will correct me if I'm wrong.
[Reply]  [No Email]
seeblackcats
09-02-2012 18:02:30
174.90.110.79
 Re: ford serial # in reply to Ultradog MN, 09-01-2012 18:27:40
I found the rest of the numbers from the tractor.
1 st number is 35012G
2 nd number is 8A22b
3 rd number is C192761
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
