| Ford Tractors Discussion Forum |
Topic: Wiring a 641 Ford - Accessory Question
[Return to Forum]
| Author |
[Modern View]
| rtr
09-01-2012 09:20:54
98.83.136.225
 I am adding some 12 volt electric "air horns" to my 'reconditioned/restored' Ford 641 tractor. I have a question about how I should hook up the wiring regarding the diagram below. I feel like I should use an inline fused wire, and hook it to the junction block as per my drawing on the diagram. Please provide me with input, thoughts, and concerns. THANKS! |
| RTR
09-02-2012 14:47:06
174.154.129.143
Re: Wiring a 641 Ford - Accessory Question in reply to LME, 09-01-2012 09:20:54
| Quoting Removed, click Modern View to see
Thank you sooo much!!! Nice job |
| Sean in PA
09-02-2012 11:38:01
71.224.102.32
Re: Wiring a 641 Ford - Accessory Question in reply to rtr, 09-01-2012 09:20:54
| RTR
09-02-2012 09:14:01
74.248.177.3
Re: Wiring a 641 Ford - Accessory Question in reply to soundguy, 09-01-2012 09:20:54
| Well if you have the time (and know exactly how it should go), take my wiring diagram and draw in what I need to complete the wiring for the horn USING A RELAY & FUSE SYSTEM.
I have a good idea of how it should go, but would like one of you experts to draw it out so I know I am right!
THanks again. |
| NoNewParts
09-02-2012 04:28:08
67.240.145.25
Re: Wiring a 641 Ford - Accessory Question in reply to George Marsh, 09-01-2012 09:20:54
| Sean in PA
09-01-2012 13:41:39
71.224.102.32
| Yes, the diagram is correct for a basic circuit to run the horn, but as I said, the horn will operate with the key switch in the off position, so there is a potential for someone, like kids, to run the horn when the key is off and for the battery to be run down as a result. If you have no worries in that regard, then it is fine as is. |
| Sean in PA
09-01-2012 10:03:06
71.224.102.32
| First, you probably know this and just forgot to mention it or put it in your diagram, you'll want to add some kind of switch (spring loaded push button or something similar) or the horns will be on all of the time with that diagram. Second, if you want to keep kids from wearing down your battery by playing with the horns when you're not around, you could install a relay that's controlled by a switch that's run off of the key switch, then the secondary side of the relay would connect the battery side of the terminal block to the horns via a fused line. |
| awhtx
09-01-2012 09:34:20
70.167.47.174
| You're good to go as long as you hook it to the Battery side of the junction block. The weak key switch would probably not be able to handle the current requirements for electric horns. |
| rtr
09-01-2012 11:48:05
98.83.136.225
Re: Wiring a 641 Ford - Accessory Question in reply to awhtx, 09-01-2012 09:34:20
|  You are correct. I have a push button installed on the dash. Therefore, I guess the wiring diagram would read "To Horn Switch" instead of "To Horn". Now that that has been said.....do I have the diagram drawn correctly? |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
