Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Lift Shaft on a NAA tractor
[Return to Forum]
Lonnie Hampton
08-27-2012 10:34:08
174.84.214.33
For some time now the hydrolic lift on my Ford NAA tractor does not lift the equipment high enough. I noticed that both lift arms are keywayed. The lift shaft will have to be pulled out of the lift arm housing, repositioned, and slid back into the lift housing. Is this possible to do?
[Reply]   [No Email]
36 coupe
08-29-2012 03:38:02
66.186.169.176
 Re: Lift Shaft on a NAA tractor in reply to Lonnie Hampton, 08-27-2012 10:34:08
Ive seen bent lift arms but I betting on a worn cam follower pin.Never get stuck on one idea when trouble shooting, you could be wrong.Lucky you got the arms off wth out busting the lift cover.It pays to ask questions before starting a job ,not after.Most of the fellows would have said worn cam follower pin.
[Reply]  [No Email]
Lonnie Hampton
08-27-2012 15:58:56
174.84.214.33
I ordered Hydraulic repair dvd today. Hope to see it in a couple days. Thanks
[Reply]  [No Email]
Dean
08-27-2012 11:53:13
152.216.3.5
You cannot re-index the lift arms without machining.
You can flip the lift arm end for end so that the lifting force is against the unworn side of the shaft.
Dean
[Reply]  [No Email]
soundguy
08-27-2012 11:59:17
184.245.135.4
 Re: Lift Shaft on a NAA tractor in reply to Dean, 08-27-2012 11:53:13
my bet is his lift height problem is under the cover though.. and not the heavy shaft... if his lift rockshaft bearing diameters is worn that badly, surely he'd notice it... i'd hope anyway...
[Reply]  [No Email]
Dean
08-27-2012 12:42:15
152.216.3.5
 Re: Lift Shaft on a NAA tractor in reply to soundguy, 08-27-2012 11:59:17
Of course, and did not mean to imply otherwise.
Dean
[Reply]  [No Email]
soundguy
08-27-2012 12:54:42
184.245.135.4
 Re: Lift Shaft on a NAA tractor in reply to Dean, 08-27-2012 12:42:15
i dind't think you did either.. just making sure the OP knows that, as he has asked this question twice now, and thinks the source of his lift height problem is an improperly installed rockshaft.
[Reply]  [No Email]
soundguy
08-27-2012 11:46:58
184.245.135.4
ditto again on what awhtx said.
DO get a manual or a video before pullingthe lift cover off as you can damage the backpressure valve if you snatcht he cover off without backing it off under the acorn nut.
soundguy
[Reply]  [No Email]
awhtx
08-27-2012 11:03:19
72.26.142.171
The answer is still No.
[Reply]  [No Email]
awhtx
08-27-2012 11:31:37
72.26.142.171
 Maybe this photo will help... in reply to awhtx, 08-27-2012 11:03:19
Do you see the extra wide gap between the splines in the rockshaft? The center dogbone rocker arm and the outer lift arms all have a matching extra wide spline machined inside them. There is one and only one way you can put this assembly together.
If your lift doesn't raise all the way up your cam follower pin is most likely worn. You will need to remove the lift cover and rebuild it. You can buy a video on Fleabay that shows the lift cover rebuild in detail.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
