Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Final update on 961 charging problem
[Return to Forum]
Will Gumbert
08-26-2012 18:53:17
96.239.149.197
Last week I had a post about how my 961 gasser was not charging the battery while running. This is a follow-up and hopefully it will be a help to anyone with a similar problem.
After verifying the wiring and trying a few tests including checking the battery (off tractor) for charging voltage and with a hygrometer, I decided to pull the generator and voltage regulator from the tractor and take them to a local electric shop. They had it ready in less than a day. They found the following:
- Generator needed new brushes, bearings, and the armature commutators cleaned ( the PO had gotten a little careless with the spray paint cans)
- Voltage regulator was completely shot, with cover off you could see one contact welded and the other wouldn't move
So, after putting the repaired generator in and the new Vreg, it worked good with charging voltage around 14V depending on engine speed.
Total cost was $76.
They gave me a little booklet that came with the regulator that looks like it was printed in the 60's. It outlines a procedure for testing the voltage regulator and polarizing the generator. They had already polarized mine for negative ground. If anyone is interested, I can post a copy of some pages of this booklet.
HTH -Will
[Reply]   [No Email]
Will Gumbert
08-27-2012 03:53:02
96.239.149.197
 Re: Final update on 961 charging problem in reply to Will Gumbert, 08-26-2012 18:53:17
OK, I'll give it a try. I should mention that this is for a 12V negative ground system with the diesel system wiring and generator (B-circuit), so-called stealth conversion. I'm not sure about the 6V positive ground system.
Also, I don't have any way to size these images, so bear with me.
[Reply]  [No Email]
alg
08-27-2012 02:17:14
165.89.84.88
Sure, i would be interested in seeing it.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
