Topic: Ford 4000 or 871 and SOS problems
[Return to Forum]
| Author |
[Modern View]
| jbkdwill
08-22-2012 19:52:02
70.137.1.153
I recently purchased an old Ford tractor, but have become confused on what it actually is. The owner claimed to be the 2nd owner and said it is a 4000 and it reads that on the hood(blue and white) But, the only numbers I could find hand stamped by the starter were 871 and 65892 and there is red paint under the blue, horizontal cross bars on grill and round "cyclops" emblem on front. From my research all indications are an 871 powermaster. Other number on body is 310609. Also it is a select o speed (10 speeds, 2 reverse) It will not shift into either reverse, neutral, or park unless I remove the "cap" and handle on right side of selector and turn it on around with handle off. Then it will shift through all gears fine. Any ideas? It looks as if that right side "plate" the lever rides in is pretty worn. |
| jbkdwill
09-08-2012 06:01:25
70.137.25.215
Re: Ford 4000 or 871 and SOS problems in reply to jbkdwill, 08-22-2012 19:52:02
| [quote="awhtx"](quoted from post at 19:32:30 08/23/12) The best places to look for original gold paint are under the lid of the toolbox and under the hood around and behind the air cleaner.
When Ford introduced the SOS trans in Jan 1959 they required every dealer to buy one to demonstrate to his customers. They were painted gold to make them stick out like a sore thumb and thus the "Gold Demonstrator" nickname was coined. Most people couldn"t care less but they do have some additional values to collectors.[/quote]
After a couple of weeks of working on my tractor I have found gold paint everywhere! You were right on the money. Would say it was def a Demonstrator. |
| Larry NCKS
08-23-2012 11:49:36
64.254.59.123
Re: Ford 4000 or 871 and SOS problems in reply to petetherookie, 08-22-2012 19:52:02
| This is neither here nor there for this discussion, but IH also did this in the early 70s when the 826 was introduced. The hood and fenders were gold. The rest of the machine was IH red. That was one good looking tractor. |
| Larry NCKS
08-23-2012 05:05:16
64.254.59.123
Re: Ford 4000 or 871 and SOS problems in reply to RTR, 08-22-2012 19:52:02
| eBay has parts for these quite frequently. I've seen manifolds on there in the past. Here's a link to the shop manual you need. Ford Tractor Shop Manual 1955-1960 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290463247767
If your transmission casting number is still 312259 (raised letters left side above and behind inching pedal) the above manual will suffice. If it has been replaced with a C3NN-7006-B you'll also need the transmission supplement, FORD Tractor Transmission Shop Manual 1962-1963-1964 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230510621897
God bless!
This post was edited by Larry NCKS at 05:11:33 08/23/12. |
| jbkdwill
08-23-2012 04:40:06
72.24.97.19
| [size=9]To awhtx, that verifies everything I've researched so far. Haven't noticed any Gold paint. I'm going to wash it down real good before working on it, so I'll have to look. If I remember correctly from what I've read, the Gold models were "specials"? Would that add any value? Too be honest I just bought this tractor to mow around my property and disc up food plots. Not real familiar with the history of them except my Dad had a 9N when I was a kid and ran forever. For $2500, I think I did alright?[/size] |
| awhtx
08-23-2012 10:32:30
72.26.142.171
Re: Ford 4000 or 871 and SOS problems in reply to jbkdwill, 08-23-2012 04:40:06
| The best places to look for original gold paint are under the lid of the toolbox and under the hood around and behind the air cleaner. When Ford introduced the SOS trans in Jan 1959 they required every dealer to buy one to demonstrate to his customers. They were painted gold to make them stick out like a sore thumb and thus the "Gold Demonstrator" nickname was coined. Most people couldn"t care less but they do have some additional values to collectors. |
| jbkdwill
08-23-2012 04:28:02
72.24.97.19
| [size=9]
Larry, thanks for the quick response and advice. I'm new to this, so forgive me in advance if I do post something in the wrong place. I'm def going to buy a manual. I wanted to verify what I had first. I bought this tractor for $2500 with implements(think I made a good buy). Had to charge the 6v bat and jump it to get started.(sat for a year) But ran great once it fired up. The 6v will not hold a charge though. Thinking of switching to a 12v system. Will also need and exhaust manifold at some point. Any advice on good place for parts?[/size]
This post was edited by jbkdwill at 04:40:49 08/23/12. |
| awhtx
08-22-2012 20:36:17
72.26.142.171
| I bet if you look underneath the red paint you'll find gold. My 971 Gold Demonstrator is SN 65383. Your 871 was built in Feb 1959, long before the Blue & Gray 4000 series was introduced. Your engine block casting number of 310609 indicates a 172 cu in engine and is correct for your tractor's time period. |
| Larry NCKS
08-22-2012 20:05:11
64.254.59.123
Re: Ford 4000 or 871 and SOS problems in reply to Bill Radford, 08-22-2012 19:52:02
| Welcome JB. It does sound as though you have an 871 that's been repainted to later colors and had improper decals applied.
As to your SOS problem; unless that shift cap is really shot, I would start by checking shift cable adjustment. You really need a Ford shop manual for this tractor, especially if you're going to tackle the SOS. This is not an operation you wish to do haphazardly.
This post was edited by Larry NCKS at 20:12:21 08/22/12 4 times. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
