Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 3600 Blow Bye
[Return to Forum]
DEW 3600
08-21-2012 12:08:08
184.20.58.206
I was out leveling my bush hog today and noticed that I am getting a lot of blow bye on my 1977 3600 gaser. Is this something that I should be concerned about? Any help would be greatly appreciated.
[Reply]   [No Email]
David G
08-21-2012 18:40:00
64.134.172.200
 Re: 3600 Blow Bye in reply to DEW 3600, 08-21-2012 12:08:08
Try the 15W40 rotella or delvac in it.
[Reply]  [No Email]
soundguy
08-22-2012 05:14:40
184.245.35.34
 Re: 3600 Blow Bye in reply to David G, 08-21-2012 18:40:00
heck.. any 15w40, even traveler or walmart will likely do a better job than a 10w30.. i know she's a gasser.. but I like to run 15w40 in just about all mine save a couple that are getting synthetic..
[Reply]  [No Email]
Ultradog MN
08-21-2012 17:15:50
70.57.147.96
How many hours are on the tractor?
How much oil is it using? Did you use a different oil this time when you changed it?
Blow by indicates a worn top end but it's not That big of a deal. Oil is cheap.
If it annoys you a lot you could do an inframe on it with new rings, rod bearings and a valve job.
Probably cost you around $400 or so if you do the work yourself and just bring the head in.
Oreilly's Auto will 'rent' you a ring ridge remover for free. Some guys here will pooh pooh an inframe and suggest you go the full monte on a rebuild.
Generally though they are talking about diesels where the engine will go 10K hours before it needs opened up and then yes do the whole deal.
On a gasser though the top end is only good for 5-6K hours(if that) while the bottom end is good for twice that.
$400 would buy you 2-3000 hours which for most of us here is many years worth of mowing and puttering around.
[Reply]  [No Email]
soundguy
08-21-2012 17:26:00
173.104.177.99
 Re: 3600 Blow Bye in reply to Ultradog MN, 08-21-2012 17:15:50
i agree.. a cyl honing, ridge reaming.. perhaps new rings and bearing shells and evena hand valve lapp can get you quite a ways down the road..
[Reply]  [No Email]
soundguy
08-21-2012 12:17:47
99.206.207.114
she making any oil?
[Reply]  [No Email]
DEW 3600
08-21-2012 13:37:30
184.20.58.206
 Re: 3600 Blow Bye in reply to soundguy, 08-21-2012 12:17:47
No it's not making any I just changed it and an it is right on or just a tad over the full mark.
[Reply]  [No Email]
soundguy
08-21-2012 17:04:28
173.104.177.99
 Re: 3600 Blow Bye in reply to DEW 3600, 08-21-2012 13:37:30
what oil ya using?
hows she start, cold and hot?
if she starts good cold and hot with no aid needed.. a lil blowby will be expected and not to worry about.
as wear increases.. blowby will increase and compression will decrease and she may drop some power and be harder to start unaided.
[Reply]  [No Email]
DEW 3600
08-21-2012 17:37:52
184.20.58.206
 Re: 3600 Blow Bye in reply to soundguy, 08-21-2012 17:04:28
I used Quaker State 10W30 when I changed it. It has 1500 hours on it. It starts very easy hot or cold I put a new Zenith Carb on it. Seems to have plenty of power I have only used it about 8 hours. I replaced the insterment cluster because the RPM needle was broken but the hour meter was working fine.
[Reply]  [No Email]
soundguy
08-22-2012 05:00:18
184.245.35.34
 Re: 3600 Blow Bye in reply to DEW 3600, 08-21-2012 17:37:52
ditto what UD and RickB said.
swap to a 15w40 oil and then work her and re-evaluate.
sounds like she is NOT ready to be cracked open if she starts fine hot and cold.
she may well limber up a bit when worked like she should.
as rick said. might be oem hours.. might not.. if she sat alot.. she could for sure act this way.
post back after a couple weeks of running the snot out of her and new 15w40 oil.
soundguy
[Reply]  [No Email]
DEW 3600
08-28-2012 19:13:16
184.20.58.206
 Re: 3600 Blow Bye in reply to soundguy, 08-22-2012 05:00:18
I changed the oil to 15w40 and worked her hard for about 6 hours and she seems to be better thanks for all the help.
David
[Reply]  [No Email]
soundguy
08-29-2012 04:20:05
184.247.53.179
 Re: 3600 Blow Bye in reply to DEW 3600, 08-28-2012 19:13:16
good luck!
[Reply]  [No Email]
DEW 3600
08-22-2012 08:46:23
184.20.58.206
You have all convinced me to change to 15W40 oil. It will be a while before I can do anything to her. My wife just had surgery on her foot and will be laid up up 6 - 8 weeks so I guess I get to be the house keeper and cook for the next month and a half. Thanks again for all the info.
[Reply]  [No Email]
soundguy
08-22-2012 10:01:32
107.41.212.71
 Re: 3600 Blow Bye in reply to DEW 3600, 08-22-2012 08:46:23
that oil change will be a great way to spend 10-15m in 2-3 shots out of the house for a break.
1 to get a pan and pull a plug... then let her drain.
the next to repalce plug and spinn off/on filter.
then the next to pour oil in.
good luck
soundguy
[Reply]  [No Email]
Ultradog MN
08-21-2012 17:50:28
70.57.147.96
You don't need a rebuild.
Go work the snot out of it for half a day or a day.
Really work it.
Then post back.
With 1500 hours it's probably been laying around in a shed it's whole life and never worked.
I'll bet it will clear up a lot.
I would run a little heavier oil in it. I usually buy a generic diesel rated 15W40 from Fleet Farm and run that in my tractors.
[Reply]  [No Email]
DEW 3600
08-29-2012 06:30:59
184.20.58.206
 Re: 3600 Blow Bye in reply to Ultradog MN, 08-21-2012 17:50:28
David
[Reply]  [No Email]
DEW 3600
08-21-2012 18:15:34
184.20.58.206
Thanks for all the info. I think the she hasn't been well mantained and has set out in the weather paint is really faded I belive the hours to be correct because the old cluster that I took out was made in England. She seems to be a good tractor got her for 3250 with a 6ft Ford 951 Special bush hog. I thought it was a pretty good buy.
[Reply]  [No Email]
RickB
08-22-2012 02:45:11
69.195.58.87
 Re: 3600 Blow Bye in reply to DEW 3600, 08-21-2012 18:15:34
Could be an original proofmeter that had a broken cable for 20 years. or the hours could be correct.
I'd change to a quality 15W-40 and run the snot out of it before tearing it down.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
