Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Hydrologic Leak
[Return to Forum]
Danny P.
08-21-2012 06:34:52
170.141.177.87
I have a leak on my 1967 3000 ford diesel where the pump mounts to the trans case. I can't seem to locate a gasket anywhere for it. Can I make one out of cork gasket material? Thanks.
[Reply]   [No Email]
RodInNS
08-21-2012 08:40:30
216.118.158.123
 Re: Hydrologic Leak in reply to Danny P., 08-21-2012 06:34:52
It's a paper gasket that also acts as a shim for the backlash on the cam gear. The correct gasket is readily available and generally in stock at any NH dealer. You could make it if you know the thickness of the gasket paper required. I don't know off hand...
Rod
[Reply]  [No Email]
Ultradog MN
08-21-2012 17:37:59
70.57.147.96
 Re: Hydrologic Leak in reply to RodInNS, 08-21-2012 08:40:30
FWIW,
I have 3 of those gaskets here so for kicks I measured them up.
1) new aftermarket = .0195
2) new CNH = .0201
3) old NOS Ford = .0189
The NOS one is dry and brittle and might have shrunk.
Unless I was in a hurry I wouldn't bother trying to make one. As you say, any CNH dealer will have one in stock and can mail it to you for 1st class postage if you ask.
[Reply]  [No Email]
Danny.P
08-21-2012 08:20:06
170.141.177.87
I believe it's coming from the gasket. I'll clean it good and make sure where the leak actually is. Thanks.
[Reply]  [No Email]
soundguy
08-21-2012 07:24:16
184.246.237.93
is it really leaking at the gasket.. or at the compression pressure tube?
[Reply]  [No Email]
Sean in PA
08-21-2012 07:03:22
71.224.102.32
Are you talking about the hydraulic pump? It actually mounts to the engine at the flywheel, but most of the body of the pump is rearward of the mounting point so it looks like it is mounted on the transmission. The original part number for that gasket is E4NN911AA, which shows as no longer available, but Messick's shows that it was superseded by part number 83948101, and it shows that they have 4 of the newer part number in stock for $6.38 a piece.
What's leaking there hopefully isn't hydraulic oil, it should be engine oil. If hydraulic oil is leaking there, then there's another leak inside the pump itself, and your crankcase oil is probably contaminated as well.
This post was edited by Sean in PA at 07:11:01 08/21/12.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
