Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 8N problem
[Return to Forum]
Big H
08-20-2012 12:49:05
216.12.60.4
My 8n only runs smooth with the choke on, if I disengage the choke it starts spitiing and sputtering. Anyone have any idea what could cause this?
[Reply]   [No Email]
showcrop
08-21-2012 05:03:27
75.67.231.80
 Re: 8N problem in reply to Big H, 08-20-2012 12:49:05
Needing choke means it needs more gas. You can get more gas by lowering the float in the carb float bowl so that it will rise to a higher level before closing, or by clearing a partial plug. As Phil and Old said remove the plug on the bottom and watch for FLOW for about 1/2 minute. ten seconds flow followed by a drip will not keep your motor running. If it is slow back track to find the obstruction. If flow is good and float level correct, the carb needs complete dis assembly, soak, and cleaning of all passages.
[Reply]  [No Email]
Big H
08-21-2012 15:16:43
216.12.60.91
 Re: 8N problem in reply to showcrop, 08-21-2012 05:03:27
Thanks for the info. I'll double check the carb and the spark. Thanks again.
[Reply]  [No Email]
Phil B.
08-21-2012 04:38:40
50.195.47.81
It sounds like your carb needs cleaning and or rebuilding. If it"s been sitting a while, the ethanol gas will eat it up and the rust will clog up the jets. Also check if you are getting good fuel flow from the tank. Good Luck
[Reply]  [No Email]
soundguy
08-20-2012 16:27:20
184.246.193.72
lack of fuel in the combustion chambers maybee?? :)
[Reply]  [No Email]
old
08-20-2012 14:46:41
209.86.226.40
Front or side mount distributor??? 6 or 12 volts??? Lack of info makes it hard for us to help you help your self.
Having to choke it can be one of 2 things. #1 poor/weak spark and a rich mixture burns better then a lean one so check you spark. It needs to be a blue/white in color and jump a 1/4 gap. Next pull the carb drain plug and let the fuel flow for a few minutes. Catch it to make sure it is not full of dirt/rust/water. If you have a good flow try opening up the main jet a little bit at a time. You should be able to open it up to a point that you get black smoke if not then the carb maybe clogged up
[Reply]  [No Email]
Larry NCKS
08-20-2012 13:34:15
64.254.59.123
 Re: 8N problem in reply to Bern, 08-20-2012 12:49:05
Try some carburetor adjustment. If that won't do it, you'll need to overhaul the carburetor.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
