Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 861 loses power and surges after engine warms up
[Return to Forum]
Mike in Elizabeth
08-19-2012 21:24:34
72.42.69.153
Hoping for a little guidance here. I have a late 50s model 861 that acts like it's vapor locking after a few minutes of running. Doesn't seem to matter too much what the outdoor temp is. I've played with fuel line routing and checked the bowl screen and gas tank filter. There's no external gas filter. I get some boiling in the gas tank, is that normal? When I pull the choke it'll run ok for a couple minutes then start to buck again. I rebuilt the carb and nothing changed. Not sure what to do next.
[Reply]   [No Email]
soundguy
08-20-2012 09:13:52
173.105.67.226
 Re: 861 loses power and surges after engine warms up in reply to Mike in Elizabeth, 08-19-2012 21:24:34
once you spark test it to decide whether fuel or electrics as AWHTX suggested.. if it is fuel.. see if choke helps.. then see what if any tank vacume you have.. be carefull.
next.. see if there is a restriction in the flow to and thru carb
post back
[Reply]  [No Email]
Mike in Elizabeth
08-20-2012 09:31:00
72.42.69.153
 Re: 861 loses power and surges after engine warms up in reply to soundguy, 08-20-2012 09:13:52
Good suggestions. I've already checked fuel flow, though to be honest it's still possible a passage could be gummed up in the carb. For the couple bucks a condenser costs that's an easy one to just replace as a test. Thanks. Will post back after I have a chance to check these out.
[Reply]  [No Email]
soundguy
08-20-2012 11:15:12
184.233.5.18
 Re: 861 loses power and surges after engine warms up in reply to Mike in Elizabeth, 08-20-2012 09:31:00
swapping in an unknown part is rarely a good test. a condensor may be bad out of the box.
this really sounds like fuel.. not a condensor.
if it is an open condensor, the points will burn.. if it is a shorted condensor the spark will be weak.
is spark is weak.. post back.
[Reply]  [No Email]
old
08-20-2012 09:50:10
209.86.226.40
On most a suging engine is caused by lack of fuel as in a clog in the man jet and some times that is a simple easy fix by pulling the air cleaner tube and fire it up and put your hand over the air intake and hold it there just long enough for the engine to die down but pull your hand off before it dies. Do that 2 or 3 times and a lot of times that is enough to suck the dirt out of the main jet and then the problem goes away
[Reply]  [No Email]
BruceR TN
08-21-2012 15:44:58
74.34.108.67
 Re: 861 loses power and surges after engine warms up in reply to old, 08-20-2012 09:50:10
Old, been a while since I did that but it works most of the time. Learned that trick on my "63 Chevy with the 2 barrel Rochester carb.
[Reply]  [No Email]
awhtx
08-20-2012 04:48:01
12.183.46.66
Next time it does that immediately pull a spark plug wire and using an old plug with the gap opened up to at least 3/16" check for spark. My 851 was doing something similar and it turned out to be the condenser.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
