Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: distributor fit help 800
[Return to Forum]
corvetteguy
08-17-2012 03:40:39
65.167.42.181
Have a Ford 800 engine to put in my 821 Backhoe.
(got backhoe with a 62 Jeep engine). Removed
distributor to paint engine and marked rotor
position. Tried to put back in and won"t go down
the last 1/4 inch. The gears are engaging. Flywheel
was not turned.
What am I doing wrong???
[Reply]   [No Email]
NoNewParts
08-19-2012 12:17:03
67.240.145.25
 Re: distributor fit help 800 in reply to RodInNS, 08-17-2012 03:40:39
factories using what was on the shelf,
then, since it's not really a sediment bowl anymore,
some enterprising engineer probably re-named it,
'an easy-clean see-thru inline fuel filter' :D
[Reply]  [No Email]
JMOR
08-18-2012 21:07:32
72.181.173.171
 Re: distributor fit help 800 in reply to FarmerZeb, 08-17-2012 03:40:39
Quoting Removed, click Modern View to seeClearly, it will settle on the screen! Doesn't sound like a good design to me either? But they did plenty of them.......search the junk yards, particularly GM.
[Reply]  [No Email]
Royse
08-18-2012 20:51:25
69.36.49.151
 Re: distributor fit help 800 in reply to corvetteguy, 08-17-2012 03:40:39
Just curious, how is sediment supposed to settle if its upside down?
I always thought these things worked on the same basic principal as
a septic tank.
I know I've cleaned enough crap out of them to qualify! :lol:
[Reply]  [No Email]
JMOR
08-18-2012 20:42:20
72.181.173.171
 Re: distributor fit help 800 in reply to KCTractors, 08-17-2012 03:40:39
Unless we are going blind! Upside down was common on many cars during the 40s-50s.
[Reply]  [No Email]
Sean in PA
08-18-2012 17:16:08
71.224.102.32
Is that an upside down sediment bowl attached to the fuel pump in that picture?
[Reply]  [No Email]
JMOR
08-18-2012 10:23:19
72.181.173.171
 Re: distributor fit help 800 in reply to FordManiac, 08-17-2012 03:40:39
Quoting Removed, click Modern View to seeReason I asked, I would expect that you had to get a "real deal" on it if it were still working. Large (even medium) power units are not cheap, paid several thousand for an 'old' one powered by 6 cyl Ford, last year.
[Reply]  [No Email]
corvetteguy
08-18-2012 14:44:12
65.167.42.181
 Re: distributor fit help 800 in reply to JMOR, 08-18-2012 10:23:19
Not sure of the deal but I gave $400
for the setup. I don't see any leaks
It had a Ford sticker Industrial Power Products
Model B8PD -6002GP1 172 cu in
The power unit has a front for radiator
and a rear handle operated clutch with
a direct drive to a large 4 groove pulley
[Reply]  [No Email]
JMOR
08-18-2012 08:31:27
72.181.173.171
 Re: distributor fit help 800 in reply to GT65, 08-17-2012 03:40:39
Good deal. Glad it worked out for you. Was the power plant generator bad/scrap?
[Reply]  [No Email]
corvetteguy
08-18-2012 09:58:06
65.167.42.181
 Re: distributor fit help 800 in reply to JMOR, 08-18-2012 08:31:27
No
I bought the "working" 800 stationary power
unit because I need a complete 800 engine for my
821 back hoe. It came to me with a butchered bell housing
and a 62 jeep 4 cylinder.
I wanted to go back to a regular ford engine
so I need everything.
I am still short
1) hydraulic pump.
2) Air filter and tube.
3) choke and throttle rods.
4) Radiator.
I think I can cobble up everything else.
I still have the power unit so maybe I can trade
or offset the costs so far..
[Reply]  [No Email]
JMOR
08-17-2012 06:40:27
72.181.173.171
 Re: distributor fit help 800 in reply to Jeffery Rightmire, 08-17-2012 03:40:39
Quoting Removed, click Modern View to seeIf the gears are re-engaged as before removal, it should end up the same as before. Keeping in mind that as distributor drops that last 1/2 inch, the rotor will turn a little more. Once it drops, you can back up the flywheel to starting point to verify.
[Reply]  [No Email]
JMOR
08-17-2012 04:22:08
72.181.173.171
 Re: distributor fit help 800 in reply to Ultradog MN, 08-17-2012 03:40:39
Quoting Removed, click Modern View to seeGear on cam drives distributor & bottom end of distributor shaft drives oil pump. BOTH have to line up. Once cam/distr gear engaged, hold distr with hand & bump engine with starter & it will drop in.
[Reply]  [No Email]
corvetteguy
08-17-2012 05:20:08
65.167.42.181
 Re: distributor fit help 800 in reply to JMOR, 08-17-2012 04:22:08
Thanks
I'll try it, Unfortunately I will probably
loose my timing.
My next question will be How do I set timing.
Starter is off engine but I can turn flywheel.
Motor is on engine stand.
George
[Reply]  [No Email]
corvetteguy
08-18-2012 03:34:51
65.167.42.181
 Re: distributor fit help 800 in reply to corvetteguy, 08-17-2012 05:20:08
It worked like a champ. I guess the oil
pump moved a little. I set the rotor and rotated
the flywheel about 20 degrees when the dist
fell in. I rotated back to the mark. Unfortunately
I had to try twice to get the rotor in the
right position.
I took an overhead picture to help
with the registration.
I figure she should start
right up.
Now to sell the ford stationary power unit
the motor came off.
Thanks
George
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
